Question about Dell Dimension B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
I turn the computer on. Then the monitor shows the DELL startup image, with the expanding white bar below. This goes off, followed by a very brief message at the top of the screen. This goes off immediately, followed by a totally blank monitor.... nada.
any suggestions? help !
This is the Dell dimension B110 computer.
thanks,
Richard
tel 561.400.9576
  • 1 more comment
  • rpathman Nov 27, 2008
    I dont seem to have a restore fix cd.
    I am now on the BIOS setup page.... what do I do now?
    anyway I could phone you?
    thanks,
    Richard
  • macFix1010 Jan 10, 2009
    I have the exact same problem on a Dell Dimension e521 with Monitor e197fp and ATI RADEON X1300 PRO 256MB vdeo card. Were you able to resolve it ? Note: monitor seems to work perfectly until it goes to load OS - even the partial OS of "Recovery Console" makes it go blank. Is it possible that it is some setting on the Video Card which has been changed ?
  • rak108 Feb 27, 2009
    well for starters i don't what causes the problem, all i know is that the monitor goes blank ( white ) and i can't even see the mouse.... its gets quite irritating..... i think the processes are running fine, just something changed in the video card i suppose... please could you help me out?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Posted on Nov 27, 2008
I am using a Dell lap top with Windows Vista to connect to a NEC VT590 projector. I want to show a PowerPoint presentation. As the computer is booting, the computer monitor is blank and the loading...
You need to configure the projector as a second monitor as explained here
http://www.online-tech-tips.com/windows-vista/multiple-monitors-vista/
Feb 02, 2011 | Computers & Internet
My monitor shows image immediately when switched on but just as soon the image appears the screen of the monitor goes dark after that need to off/on the power switch three to four times before the image...
Please restart your computer and tap the F8 key as soon as you see something on the screen. You should get the advanced boot menu. Select Safe Mode from the list.
Let me know if you were able to boot to safe mode.
Jun 18, 2010 | Dell E193FP 19" LCD Monitor
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
The panel initially displays and then goes blank
johnerm, Good going John! At least YOU tried doing a swapout to another KNOWN GOOD pc to prove out that the E153FP is indeed the culprit!!! Now for the hard part. Do you have a bright flashlight? Reconnect E153FP to pc with WIN-desktop as the displayed image. then and only then turn on E153FP and note the time it takes to GO TO BLACK SCREEN. Is it 1, 2, --5,---20 seconds???? Now point at different angels about 1 inch from screen a bright flashlight to an area that "should" have a desktop "icon" showing. LOOK very closely!! If you SEE a very faint image of the desktop the units "switch-mode-power-supply" is in PARTIAL SHUTDOWN mode. (still has +5v or +3.3v to supply vga/lcd interface board) If you SEE NOTHING, then SMPS is in FULL SHUTDOWN mode. Get back to me, 12fixlouie with your SMPS flashlight evaluation and pay a visit to YOUTUBE fyi search and view video clips of "LCD monitor disassembly" and "LCD monitor repair" to see if DIY interests you! Also try www.ccl-la.com/badcaps.htm run by another tech on fixya nickname "buddymc" fyi. If this was of some help, rate this response on fixya. 12fixlouie aka louie12fix or lmistyrel @ aim.com
Nov 24, 2009 | Dell E153FP 15" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Screens works for 5 mins then goes blank!!!!!
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard? Ray
Jun 20, 2007 | Relisys TL565 15" LCD Monitor
Dell Dimension B110 PC Desktop Logo
1,462 people viewed this question
Alun Cox
