Question about Sony KP-61S65 61" Rear Projection Television
Sony kp61s65 dull picture
I purchased the unit in 1998. Over the past year the picutre has become dull.
Some people have warned me not to try and clean the guns and mirror myslef.
One "expert" told me that there was NO mirror in my particular model.
Any recommendations?
  • dmjach Dec 07, 2008
    Thanks chaparra559!
Well I had the same problem and my husband opened it up and cleaned it and now the picture looks very good. So u might try openning it up and cleanning it ur self.
Posted on Dec 06, 2008
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
My sony projection screen tv the colors are not lined up and i am try to find out how to adjust them so it works again
I think your convergence is out of align. I looked at the manual on the sony site. Setting it starts on page 14. If you don't have the manual you can find it here http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP61S65
Mar 02, 2010 | Sony KP-61S65 61" Rear Projection...
No Picture. Started with picture intermittently
COULD BE GENERAL SERVICING, THIS INCLUDES DRY JOINT..RESOLDERING THE HEATED PLACES, ON BOARD, SECONDLY, IF PICUTRE IS COMING AND GOING OUT CAN BE ALSO A VERTICAL IC PROBLEM, NOT TO REPLACE, RESOLDER THE UNIT AND TRY TO ON, SHOULD SOLVE THE PROBLEM
Oct 14, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
I have had my Sony KDF-60WF655 unit and the screen is going dark.
The screen is dull but I can see the picture , Will changing the bulb help?
Sep 06, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Dull / dark screen and picture quality not sharp
The cooling fluid in the blue and perhaps the green picture tube assembly has become contaminated. Only solution is to remove the assembly and dump old fluid and clean and reinstall new fluid.
Apr 30, 2009 | Televison & Video
The color seems to be fading. NOt a clear picture.
Likely the picture tubes are getting weak from old age. Not much you can do about this.
Mar 30, 2009 | Televison & Video
Dull picture on my KP61s65
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Nov 27, 2008 | Sony KP-61S65 61" Rear Projection...
1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
May 04, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Sony KP-61S65 61" Rear Projection Television Logo
284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
