Error code F61 on Technics SC-DV150
Dave
Thank you very much for responding to my message. My background is not electronics based. However, I am very practical having spent thirty years in the Construction Industry. For your information the system worked fine after I posted the message and again today. This evening it went back in to fault mode. I noticed that it clicks several times before it switches off. Does this give you a better understanding of what the problem might be. I do have a multimeter in my tool kit but not a small soldering iron (150watts is the smallest) However, I could purchase one as they are cheap. I will await your thoughts before I do anything.
Thank you again for your kind offer of help.
Mike.
    President:
  • 624 Answers
Yes, this could be the solder connections on the amp and power supply. You will need to take the unit apart to take the boards out, then reflow all the solder connections that are not a shiny silver color and/or have a ring-like crack around them, or if they look a little grainy. The clicking is the relay going on and off. This could be because the power supply voltages are not constant. It may also need a couple of capacitors replaced in the power supply. If the unit was working for a day or 2 and then it stops, and then it will work again, it is most likely some bad solder connections.
As long as your soldering iron will melt the solder, it should work OK for you to do this. Just be very careful to not make any solder bridges. A solder bridge is when the solder from one pad is leaked over to another pad next to it. Always inspect the circuit board after reflowing a lot of solder connections with a magnifying glass so you have a very good view of every connection. If just one of those solder connections has even a small little string of solder that connects to a solder pad next to it, it can cause serious damage to the unit. It creates a short where there is not supposed to be one.
The information I have given you is based on over 18 years of repairing audio equipment, but that does not mean I am always right when I have not had the chance to see the unit myself. All I can do is guess and tell you the most likely causes, that means that there are other causes and sometimes those other causes are very difficult to isolate without troubleshooting it myself.
I hope this has helped, just let me know if you need more help. I may not get back to this site today, I am spending Thanksgiving with my family here at my home and may be to busy to respond back again today.
Happy Thanksgiving
Dave
Posted on Nov 27, 2008
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Dec 24, 2008 | Panasonic SC-BT100 Theater System
The F61 error is an amplifier failure.This error can be caused by a blown channel or even a failure in the power supply which causes the unit to detect an amplifier failure because the power supply is not supplying the proper voltage to the amplifier. On more rare occasions this can be caused by broken solder connections in the amplifier and/or power supply. Without having the receiver in front of me to troubleshoot it is impossible to tell you exactly what the cause is.
It can be fixed, but it will require some decent electronic skills. If you do not have a multimeter, soldering equipment, and an understanding of electronic components it would be best to let a service center look at it for you. If you do have these tools and would like to try and fix it yourself, let me know and I may be able to guide you thru the troubleshooting process.
Dave
Nov 26, 2008 | Technics Audio Players & Recorders
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Code f61
you need to service your system,if you go to www.technics.co.uk and go to dealer locator to find a local service centre it might be costly to repair but find out before you go any further
Jul 13, 2007 | Technics SC-DV290 System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
618 people viewed this question
 Grubhead
Grubhead
