Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Toshiba regza 42inch channel browser stopped recieving info
The built in channel browser that comes with the tv was working fine for the las two years. one day it just stopped picking up the channel info.  it was a luxury i adapted to and really want it back. I hope it is something simple, can anyone help? snap mines done the same try and get into menu on dtv by pressin ad button then menu mine just displays for two seconds then goes off
4 Suggested Answers
james klgr
  • 362 Answers
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Posted on Dec 14, 2007
SOURCE: when i turn my toshiba regza on I cannot access
Try either the "content / menu" button between the volume and programme buttons. Failing that, when the tv has been powered up from the wall socket wait untill you hear a small click from the t.v (usually about 5 or so seconds after it has been switched on) before switching it on from the remote control, have no idea why this works but the dtv has worked for me ever since I powered the tv up like that
Posted on Jul 17, 2009
bobhifi
  • 635 Answers
SOURCE: TOSHIBA REGZA 24" LCD/TV cannot
When you attach a PC to an LCD TV remember to change the screen resolution of you PC to suit the LCD TV. Right click on the desktop ( not on any icon ). Click on settings / then slide the resolution pointer to a lower resolution like 1024 x 768. Then click the apply button. Try changing to different values and press apply to make it functional. One of the setting will work for you.
Posted on Mar 10, 2011
42inch Toshiba flat screen TV shows no signal on all channels. How do I fix this.
Check and replace its tuner. It is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 13, 2015 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba regza
You may have power supply trouble
May 14, 2013 | Televison & Video
How do i tune it?
If by tune, you mean program channels;
Press the menu button on the remote and select the Setup option.
Go to Installation, Terrestrial, Channel program, start.
This will automatically add all the channels to your television that you are able to recieve.
Mar 05, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
Jan 31, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Two DVD's stuck in Toshiba Regza with built-in DVD player
If you can find a piece of stiff wire, put a small 90 degree bend onto one end and try to hook the edge or middle of the DVD drawer and pull out the drawer. It will resist a bit but should come out.
Jun 01, 2009 | Toshiba REGZA 47HL167 TV
LOST PICTURE & SOUND - UNABLE TO RE-PROGRAMME
i have a technika lcd26 207, the power button works and the light comes on, but i have no picture or no sound, just a complete blank, black screen. any suggestions please?
Mar 16, 2009 | Toshiba REGZA 26HL47 TV
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Nov 11, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
