Question about Whirlpool RF364 Electric Kitchen Range
Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
My mother's Whirpool electric oven - RF196LXMQ - will not reach 350 degrees. It will only reach just over 200 degrees. When the oven is in broil mode, the upper heating element is orange and the bottom is not. When the oven is in oven mode at 350 degrees, the bottom element is orange and the top element is not.
Which part do I need?
Thank you very much!
Jeff Boone
  • Whirlpool Master
  • 5,568 Answers
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Posted on Nov 27, 2008
Problem with oven reaching tempture setting for bakeing
make sure no one has taken it of and put it on in the wrong spot it may be reaching 350 degrees and you just dont no it
Oct 26, 2014 | Whirlpool Whirpool 4.4 cu ft Gas Range w/
Oven not heating properly
Sensor
must read 1100 ohms at room temp. If open or shorted that is yer probo. Could also just be a greasy quick connect not making a good connection.
Jan 10, 2013 | Electrolux EI30EF55GS Electric Range
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Doesn't get to correct temp set.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 05, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven will not preheat
You have burned out element(s). Lowering the wattage, therefore increasing the time it takes to reach set temp,
Apr 05, 2010 | GE JBP66 Electric Kitchen Range
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Whirlpool RF364 Electric Kitchen Range Logo
522 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
