Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
Akai PT5998hdtv sets goes on clicks and goes off
I opened the back of set and noticed the blue lamp is flickering at the same rate as the clicking noise. Red and green lights are on steady, Set turns itself off and then restarts....clicks very fast, blue lamp flickers and set goes off.
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as a comparable Samsung Model, buy the Samsung comparable Convergence board for $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than30minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy.Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked,from left,blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse.You may replace the ICs only to discover that it was another problem.Good luck, and I wish you all thebest in the repairs. I just savedabout$100 for a repairman just to showup.
Posted on Dec 11, 2008
Samsung screen flicker
Have you recently changed the resolution/refresh rate? This is usually set automaticallly by windows by check anyway.
Right click the desktop and select Screen Resolution
Change the slider/dropdown to the (recommended) selection and click apply. Click keep changes if it appears.
Still having issues then go back into Screen Resolution and click the "advanced settings" blue link on the bottom right.
Click on the "Monitor" tab and select the highest refresh rate you can and click ok. again click "keep settings" if it appears.
Dec 23, 2012 | Samsung X Computers & Internet
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
I took the back of the tv off and the blue lamp is not bright like the red and green. Could this be a coolant problem or lamp. I have the PT5492S Akai rear projection TV.
The blue is usually dimmer than the other two lens; what I would suggest is try to look into the lens with the set on; BE CAREFUL AND NOT TOUCH ANYTHING INSIDE THE SET.
If the red and green show a picture but the blue looks like a floodlight you have bad Glycol in the blue tube (common in these sets).
If all have a normal picture remember to wipe the lens clean at the top; do not try to take the lens etc apart.
Before you rate this information let me know what you find.
SD TECH
Aug 15, 2011 | Akai PT5492S 54" Rear Projection...
Screen flickers with lines but when i move the screen it stops
A nearby device can cause stray magnetic fields that will cause the display to be affected. A problem inside the monitor will cause the display to have problems. If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Sometimes if the refresh rate isnt set high enough you will see a noticeable flicker on the screen .. to change the monitor refresh rate .. you can right click on the desktop and then left click on properties .. click on the setting tab then click on the advanced tab then click on the monitor tab ..look in the drop down menu where it says 60 hertz and see if the refresh rate can be changed .. if it cant .. uncheck hide modes the monitor cant see and then click on the drop down menu .. pick a refresh rate .. 75 hertz is what i use and it should stop the flicker
ERNZ
Feb 03, 2010 | Toshiba Satellite A105-S4004 Notebook
Extended desktop flickers
Change the dots per inch -dpi setting
right click on the desktop and left click on display
open the advanced tab and you will notice monitor settings
click the drop down arrow and change the dpi number until the flickering stops.
Oct 20, 2009 | AOC Computers & Internet
Acer AL1914 flickering background
check the monitor refresh rate setting.right click on the back ground on the main windows screen. Choose proprieties from the menu that opens, then click on the settings tab on the top of property window. Next click 0on the monitor tab and increase the refresh rate at the bottom of monitor window. That should do it.
Jan 24, 2009 | Acer 19" LCD Monitor
Pop....now dead in the water ...clicks in back
CHECK THE LAMP MORE THAN LIKELY IT BLEW
OWNERS MANUAL WILL TELL YOU HOW TO GET TO IT
Feb 22, 2008 | Televison & Video
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
