Epson R200 printer - replaced cartridges but black will not print. Others are OK
Epson stylus photo r200 light print
Hi
Try cleaning the printhead and see what happens.
Hope it helps.Thanks
Sep 17, 2012 | Epson Stylus® R200 InkJet Photo Printer
My espson R200 won't print black even though it is full :s
> ESPSON
ESP-son? EPSN-Sports-Online?
Use the EPSON software to run a "print-head-cleaning" cycle to try to "unclog" the path that the ink takes from the ink-cartridge, through the "jets" onto the paper.
Nov 17, 2010 | Epson Stylus Photo R200 InkJet Printer
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
Photo R200 won't print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson Stylus Photo R200 InkJet Printer
I have the epson R200 and the ink carriage will not move across the printer anymore. You can manually move it back and forth freely.
Does anyone of you have a diagram that shows how to replace anEpson R320 Inkjet Printer Carriage Delivery Belt ? I have two of them. One has a belt broken and the other the black cartridge does not print (I have replaced it with a new cartridge and have cleaned the heads etc.) Any suggestions? If so, please email me at ril-2000@surewest.netThank you
Feb 28, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200
Sadly, if only one cartridge is empty, an Epson printer won't print. But, you can bypass that by using a chip re-setter. They have them in refill stores. By using a chip re-setter, you assign a new serial number to your cartridge, thus "fooling" the printer you have put a new cartridge in. Then, you don't need to refill all the cartridges.
Sep 09, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
How to refill Epson Stylus Photo R200 cartridges
The continuous ink kit is on sale in Canada at "The Source" (former Radio Shack stores, now owned by Circuit City --- www dot thesourcecc dot com ). Search for R200. Also the photo Cyan and Magenta original epson cartridges are under $3 and the others under 10.
Jul 28, 2008 | Epson Stylus Photo R200 InkJet Printer
Printer= Epson stylus Photo R200=will not print in black
The printer is designed so that you have to have ink in all the ink cartridges. They sell more ink this way. I have the same printer and investigated this a few years ago. there is no work around. Peter
Jan 10, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200 will not print
so after reseating all the cartridges and doing head cleaning from the computer / driver and still not getting any output on the paper :
if it´s not the printer - hopefully it´s the ink
have them replaced, contact the manufacturer
Dec 23, 2007 | Epson Stylus Photo R200 InkJet Printer
k24674
jasbo
jasbo
