Question about GE Refrigerators
Water won,t dispence from the freezer door. the water pumps to the bottom of freezer door,but don,t come out of the nozzel.
    Sergeant:
    Champion:
  • 311 Answers
Water line in door is frozen. Set frzr warmer and leave door open an hour or so so it thaws out.
Posted on Nov 28, 2008
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Does not dispence water but does make ice
When you want water, do you hear the click sound...
if not..your switch on the water handle is defective or the water control valve to defective, this is separate from the ice maker
Dec 19, 2010 | Samsung RF265AA Bottom Freezer French Door...
Water won't dispense
Your water line may be frozen through the freezer door. Remove the kickpanel at the bottom and you will see a quick disconnect. remove it and shut the freezer door and call for water. if you have water to that point then you know the line is frozen. Only fix is to replace the door or let the ref thaw for 24 hrs. Hope this helps. MJ
May 30, 2010 | GE CleanSteel GSL25JFTBS
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag mfd2561 water dispencer and ice maker issues
Most likely it is the High Voltage Control board located in the unit compartment (take off the back cover where the water lines are) i have had lots of them failing and doing all kinds of odd things, so far it has been that computer. Part number 12002608
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
