Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
PT5598hdtv 4 yrs old comes on but makes clickimg noise goes off
With back of set off I can see that the blue bulb is flickering at the same pace as the clickimg sound. the red and green bulbs are steady. All wires and connecters seem to be seated properly, however I really don't know what I looking at.
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is whatmay be the solution for most of the members who have posted theircomplaints here recently. I am not an expert, but I followed all blogsfrom various websites and forums, and the conclusion wasthe same;replace the convergence board for this model. I purchasedit from www.partstore.com and since this Akai is the same model asa comparable Samsung Model, buy the Samsung comparable Convergence boardfor $77. It came to about $85 after shipping. Call them if you need theexact model #. The Convergence board has two black STK ICs and twocolors of wires, a gray kind and a blue kind,all which have 'pins' andcan easily be unplugged from the circuit boardin the TV. It is basically a complete system that takes less than30minutes to install. It is a simple swap procedure, with no soldering.Youonly need the new board and a screwdriver! Remove thel ower backboard ofyour TV where the cables are plugged in (do not unscrew all the screwsfor the screen, as it is unnecessary, and might just damage your screenif you are not careful.) It has a u-like shape and comes off easy.Detach the gray wires connecting your old board to the rest of thecircuitry, and detach the blue wires connecting the old board to thecircuitry. On the old board, there are connectors marked,from left,blue, green and red. Detach those from the old board, and mark the wiresso that you may connect the correct the wires to the new board. You thenunscrew the only screw connecting the board to the TV,and unhook theboard from the TV. Hook the new board to the hooks which held the oldboard, and screw the lone screw to the board. Plug the gray cables fromthe new board to the connectors where the gray cables from the old boardwere,and do so for the blue cables. Connect the multicolored cables tothe blue, green and red, just as was done on the old board. Reattach thecover and test the TV. Please do not replace the two STK ICs only. WhenI removed my old board, I realized that there was a burn mark, where theICs were, but maybe it was a fuse.You may replace the ICs only todiscover that it was another problem.Good luck, and I wish you all thebest in the repairs. I just savedabout$100 for a repairman just to showup.
Posted on Dec 11, 2008
  • rippersfun Nov 20, 2010
    My convergence board died in my PT5598HD.... so I snooped around in the back room with my old AKIA 42" model PT4298HD.... amazing... the convergence boards are the same. The 42" was dead for other unknown reasons... but the 55 is back in action... took me longer to pull the back panel off the TV then id did to replace the unit... THANK YOU!
Hitachi 42" plasma 4 yrs old
I have the 55HDS52 and it flickered like crazy. The firmware was V0101.0001 and I called Circuit City and they sent a tech out with the latest fimware for my TV which is V0102.0001 and now the flicker is gone. I kept my settings all the same and watched the same reference scenes over and over and could not get it to flicker anymore. I'll post if anything changes but it seems that this worked for me. please have a look at THIS very long forum on Hitachi Plasma Noise
Dec 03, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a 20 year old honeywell quartz air/heating control. I'm not really sure how to use the heater. It has two separate toggles at the top (one blue and one red), a button that you push "up" at the...
The Blue knob is for cooling the red for heating. I would reccomend replacing it due to the fact the age and it probably has yrs of dust built up on the mercury bulbs which can throw the tempurature off. Dust on these old mecury style thermostats is its worst enemy. The bulb is very sensitve and enough dust can throw the bulb of several degrees.
Dec 18, 2008 | Heating & Cooling
Whirlpool refrig side by side
flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Oct 31, 2008 | Whirlpool Refrigerators
Medion PC model MD 1777 wabout 4 yrs old will not start/boot up. Blue light just flickers continusly and makes a tapping sound.
Remove any disk inserted n your computer (floppy or cd) and try again.
Check the cables connection and monitor connection.
If no boot, try boot your PC using the CD restore provided with your machine
Oct 12, 2008 | Medion MD-1704 PC Desktop
POPPING NOISE
mine did the same thing on a cable line and then i put rca cable on it and it never did it again
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
