Question about Saeco Magic De Luxe Espresso Machine
My magic delux is leaking water.
It leaks and only fills half the normal amount. The water ends up under the machine (small amount) and also fills the tray.
Thanks, Johnemac
  • steviethek Feb 02, 2009
    mine started doing the same thing recently. over time more and more leakage and less water into the cup, finally no water dispensed at all.
  • Sueowens May 04, 2009
    My problem is the same, water leaking all into the tray and inside the front of the maker. Lots more water all clear. I get 1/2 cup of coffee...I am looking for a dealer in Portland , Oregon area....any suggestions?
    Problem Solver:
  • 8 Answers
Possibly coffee grind to fine (adjust to a coarser grind) or blocked filters in central unit, try using a brewer de-tannin powder to clean. If neither of these seem to be the problem check the o ring that seals the central unit to the machine which may be leaking - if you remove the central unit you will see a cutout in the side panel of the machine inside you should see a vee shaped nozzle with an orange o-ring that may be the problem.
Posted on Jan 09, 2009
  • 3 Answers
I had a similar problem, this is how I solved it. When you pull out the plastic unit from the side to clean it you should see a small little spout where the pressed hot espresso goes through. For me, that spout wasn't made too snug, so i wraped some white Teflon tape around it. After cleaning the unit and replace it via the side door, it now feels a bit snugger, and doesn't leak any coffee.
Posted on Feb 16, 2009
  • 1,089 Answers
Hi
Sorry to say yoou have a leak in the boiler. If its the older model with the six buttons shaped like a triangle, you are going to have to replace the boiler. If its a newer model with the buttons 3 on top and 3 below, you might have a broken line going to the boiler.
Posted on May 20, 2009
  • 68 Answers
I hope i can help unplug from the wall, lift the machine up to see where the water is. now open up the machine when you have opened up check for a hair line crack. check the seals and check wher it is going into the tray
Posted on May 04, 2009
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
Our 7 year old Saeco Magic Delux has started to leak water when we fill the tank. It runs out of the bottom of the tank and down the side. Happens about 20% of the time. Is it worth having a 7 year old one...
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Magic De Luxe Espresso Machine
Whenever i park the car water leaks out of the tiny hole under the rad cap ! Why ?
In the cooling system of the car,there is a fair amount of water.When it gets hot it expands.It will half fill the overflow bottle.If you top up the water too far,it will flow out the hose,or hole as you said.This is normal.If it flows out a lot,and you have to refill the bottle very often,this is something that needs looking at.But a small amount is normal only once or twice after topping up.Just make sure is not the aircon,drain.I hope this helps
Sep 24, 2009 | 2005 Peugeot 405
Saeco magic deluxe is leaking water
Either two faults, one is that the boiler is leaking ( fix this straight away as water can spray on main circuit board and short out ) very costly to repair if both needs replacing. Second the water runoff to the front tray is blocked with coffee grime . Instead of the water left over when the brewer dissengages running off to the front tray it overflows into the machine. Hope this helps
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Water leaking from the tank & down the outside of the Magic DeLux
I have a Saeco Magic Deluxe that does/did the same. The water tank, when filled would empty down the side of the machine and all over the counter top.
I recognized that the lid on the water tank, when pressed firmly in place, created a back-pressure because air was not able to get into it and level out the pressure. I've resolved this problem by leaving the lid slightly ajar allowing air to circulate into the water tank itself. I've also thought about drilling a tiny hole into the lid itself but have not done that yet for I don't want to comprimise the plastic.
Peter (Detroit, MI)
Feb 21, 2009 | Saeco Magic De Luxe Espresso Machine
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
I have a Saeco Vienna Deluxe Model. We have been experiencing water leaking from the machine. It leaks under the tank and floods the counter or leaks into the spent coffee disposal bin. I removed and...
If it leaks under the water tank then you have to replace the gasket in the machine where the water tank inlet are.
If you have a leek inside the door, make sure the hole behind the brewing unit (in the chassis) are clean.
That you get a half cup of coffee one time and a full next time can be the electric board in the machine but can also be the flow meter.
Hope this can help you.
Best regards
/Mirran
Aug 25, 2008 | Saeco Vienna De Luxe Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Magic De Luxe Espresso Machine Logo
301 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
