Question about Epson Perfection 610 Flatbed Scanner
I need a driver for the scanner perfection 610 for windows vista
Is it possible to use the scanner perfection 610 on the vista.
  • 51 Answers
As Epson does not have drivers for this Vista, have you tried the driver for Windows XP?
You can find them here
Hope this can help.
Posted on Nov 28, 2008
My epson perfection 610 scaner is connected with connected with my computer i want to down load the software/drivers
Hi!
You need to go to www.support.epson.com select your scanner and download the software that will work with your Operating System.
Hope this helps. Keep me posted.
Apr 12, 2011 | Epson Perfection 610 Flatbed Scanner
Epson has no drivers for 3200 perfection photo scanner for win 7 pc.can you helpwith something besides vuescan?
Please go to this page and download the drivers for Vista. Well over 90% of Vista Drivers work perfectly for Windows 7, BUT! not 100%. I've solved many driver issues for local customers this way and I hope it works for you.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=20882&prodoid=27766185&infoType=Downloads&platform=All
Regards,
Selk
Apr 03, 2011 | Epson Perfection 3200 Photo Flatbed...
Can I get a driver for the epson perfection 1200 scanner that is compatible with windows vista. at present it will not work with vista and I am told no driver is available, otherwise I have to buy new...
this is pretty ancient model, but... you can try to use winxp twain driver and it should work, your registry most probably will need bit of tweaking... version which will most probably work is TWAIN Driver v5.53A,
follow this procedure, disconnect your scanner from computer, run ccleaner to clean all rubbish, including registry clean.
download twain driver and then run it, force vista to accept it, reboot your computer. connect scanner and you will have then warning from vista about digital signature, disregard it and force install software. scanner should work.
i still would suggest newer version...
Jul 20, 2010 | Epson Perfection 1200 Photo Flatbed...
I need to know where to get a Vista driver for Epson Perfection 610 scanner
Hello !
Unfortunately, there is no free solution to your problem. No Vista driver has been written for your scanner.
But, there is a solution. Vuescan has a product here:
http://www.hamrick.com/ It does cost $39.95, but there is a free trial.
Hope this helps.
Sep 25, 2009 | Epson Perfection 610 Flatbed Scanner
Looking for drivers for epson perfection 1660 photo scanner on a windows vista 64bit system. any help would be welcome. thank you
Vista x64 and Windows 7 x64 driver for Epson 1660 scanner is found here:
http://www.vistax64.com/drivers/185132-unofficial-drivers-epson-perfection-1660-scanner.html
Apr 16, 2009 | Epson Perfection 1660 Photo Flatbed...
Unable to install scanner
Cant find such a scanner, are you sure of the model "performance", If it is not Vista compatable, ie if Epson have not released a Vista driver, then it is not going to work with Vista.
See Epson web and download driver if available, if not change scanner or operating system or purchase software
Check your Epson product CD to see if it already contains Windows Vista drivers. If the CD indicates support for Windows Vista, follow the instructions that came with your Epson product to install your driver and other software.
If your Epson CD does not indicate support for Windows Vista, DO NOT INSERT YOUR EPSON PRODUCT SOFTWARE CD IN YOUR WINDOWS VISTA COMPUTER because the setup program is not compatible with Windows Vista. Instructions for installing additional software from your CD may be available with your driver download.
Note: If you already have ArcSoft PhotoImpression™ 5 installed on your Windows Vista computer, you may need to install a "patch" program. Go to the ArcSoft website to download and install the patch.
Products that are not Vista compatable are not capatable with Vista, who would figure hey!!
Jan 23, 2009 | Office Equipment & Supplies
Scanner doens't work on Vista
Go to the HP website and under the support section see if there is a windows vista driver available for your model #. If there is then download & install. Scanner should then work. Hope this helps & please remember to rate my answer. Thanks.
Jan 08, 2009 | HP Scanjet 3300c Flatbed Scanner
No drivers for windows vista
Perfection 1200U Photo Scanner for Vista
Jul 11, 2008 | Epson Perfection 1200 Photo Flatbed...
UMAX 4100 Driver for Vista
go to UMAX 4100 scanner installation CD that comes with the scanner and find the setup.exe file and on it clik left mouse and then right mouse and choose properties and then choose "Install in WinXP-Sp2 compaitibility mode" ...Thats its . Then it will install in Visa and will work perfectly. Only when you startup the Vista it gives you some error message "incompitable Os" etc ..just cancells the message ..and your Umax 4100 Scanner will work perfectly.
Ray
Jun 02, 2008 | Umax Astra 4000 USB Flatbed Scanner
Epson Perfection 610 Flatbed Scanner Logo
1,013 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
