Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv channel will not change and volume keeps increasing without to
Volume is increasing without touching it; and channels will not change
  • 3 Answers
Most likely you have a defecvtive volume up switch. Unsolder it from the board, and see if problem goes away. Very common problem. Since only one function can work at a time, none of the others will work until you "release" that switch
Posted on Dec 01, 2008
Can I turn off my 55 inch Samsung tv without using my Comcast control? My Comcast control does not work.
Hope this helps.
What is Jog Controller in Samsung TV's ? Last Update date : 2016.11.11
The Jog Controlfeature is a quick and easy way to enable and access certain functions and features on yourSamsung TV without a remote control. Television now use a Jog control instead of touch buttons to control the TV without the remote control. This control is located on the rear or bottom right side of the TV and will feel like a little joystick. Move the Jog conroller towards the icons indicated on the all four sides to control channel and volume. Press and hold the Jog controller to turn off the TV.
Here are some description of Jog Controller :
Channel Up : Changes the channel upward.
Channel Down : Changes the channel downward.
Volume Up : Increases the volume level.
Volume Down : Decreases the volume level.
Display on the bottom right of the TV screen opens by pressing Jog Controller once :
Smart Hub : Opens up Smart Hub.
Return : Brings back to the TV viewing.
Source : Changes the source.
Power Off : Turns TV off.
Menu : Opens up the TV Menu.
Related Model Information PS43E400U1R, PS43E470A1R, PS43E490B3R, PS43F4100AR, PS43F4900AR, PS51E470A1R, PS51E490B3R, PS51E550D1R, PS51E8000GR, PS51F4900AR, PS51F5500AR, PS51F8500AR, PS64E8000GR, PS64F8500AR, UA22ES4003R, UA22ES5000R, UA22ES5005R, UA22ES5100R, UA22F5000AR, UA22F5100AR, UA23F4002AR, UA23F4003AR, UA26EH4000R, UA26EH4800R, UA28F4000AR, UA28F4100AR, UA32EH4000R, UA32EH4003R, UA32EH4500R, UA32EH4800R, UA32EH5000R, UA32EH5330R, UA32EH6030R, UA32ES5600R, UA32ES6200R, UA32F4000AR, UA32F4100AR, UA32F4500AR, UA32F4800AR, UA32F5100AR, UA32F5500AR, UA32F6100AR, UA32F6400AR, UA39EH5003R, UA40EH5000R, UA40EH5330R, UA40EH6030R, UA40ES5600R, UA40ES6200R, UA40ES6600R, UA40ES6800R, UA40F5000AR, UA40F5100AR, UA40F5500AR, UA40F6100AR, UA40F6400AR, UA40F6800AR, UA40F7500BR, UA46EH5000R, UA46EH6030R, UA46ES5600R, UA46ES6200R, UA46ES6600R, UA46ES6800R, UA46ES7500R, UA46ES8000R, UA46F5100AR, UA46F5500AR, UA46F6100AR, UA46F6400AR, UA46F6800AR, UA46F7500BR, UA46F8000AR, UA50F6800AR, UA55ES6200R, UA55ES6800R, UA55ES8000R, UA55F6400AR, UA55F7500BR, UA55F8000AR, UA55F9000AR, UA60ES8000R, UA60F6400AR, UA65ES8000R, UA65F8000AR, UA65F9000AR, UA75ES9000R, UA75F6400AR, UN26EH4000M
Jan 27, 2017 | Samsung Televison & Video
AUTOMATICALLY CHANNEL / VOLUME AND MODE CHANGING
please check touch key board i think it is defect
thanks lal electronics
Jul 15, 2013 | Insignia 32" 720p Flat-Panel LCD HDTV
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
Tv channel is automatically changing
sounds like it need some cleaning , or main board might be disaligned , open it and take a look at the plastic buttons that touches the main board switches , good luck , AJ
Oct 24, 2009 | Televison & Video
The tv keeps on changing channels without the remote, then sometimes is turns off when we change the volume...
Hi,all the tack swicth of your front panel tv is defective ,because as you said when you change the volume sometimes is turns off meaning you have coroded swicth that makes your system control IC of your tv malfunction when you touch the button,in this case you may need tv technician to repair it.
hope it may help,
Oct 04, 2009 | Philips Magnavox TS3260C 32" TV
TV won't stop changing channels
Main board needs replaced !
Jul 03, 2009 | Televison & Video
Channels changing on its own, sound increasing on its own
Do you know where your remote is?I have had it where it would do that for days and then I would find my remote was wedged into my chair somewhere and when I sat down it would press a button.Either that or check the wires in the remote and TV.For the changing channels do you look at your remote when you press buttons to switch channels?There is a common button,which,when pressed,will surf through all of your tv's channels.
Jan 31, 2009 | Sony KLV-S26A10 26 in. HD-Ready LCD...
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
