Dishwashers Logo
Posted on Nov 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All lights on the control panel work, but no water comes in.
This happened after a power outage in our area.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 304 Answers
  • Posted on Nov 27, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
304
Questions
0
Helped
115782
Points
831
Id there any error codes appear on thepanel..
try to unplug the unit for at leat an hour.
post bvack again how things get done.
1helpful
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Control panel is not responding
Most likely, if power *is getting to the unit*, (there are lights lit on the washer), then the culprit will be a shorted user interface board(control panel). This is a fairly common type of issue with dishwashers. The soft-touch buttons or the touch panel has a shorted button or area(depending on the type you have) and nothing else will function because the unit thinks you're still pressing a control button. Also, a VERY common cause of this issue, aside from moisture or bugs, is a power outage damaging the console when power is restored due to a surge. After an outage where damage occurs, the symptoms don't usually start for about 3-4 weeks after due to damaged chips on the board starting to fail.
Aug 20, 2015 • Dishwashers
2helpful
2answers
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
1helpful
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
After a power outage the TV will not turn on. The reset light flashes continuously. Pushing the reset stops it, but it resumes flashing as soon as the reset is released. I tried unplugging the TV for...
i have encounter many of these issues with TVs going bad after a power outage which i something that can be complex. Actually almost all the TVs go through this issue sometimes in their life time.
What happens is that TVs have a circuit that controls the on/off phase; the circuit has resistors, diodes and capacitors to do the job. When there is a power surge, which is what happens when the power come back on, a diode, resistor or capacitor goes bad. Capacitors are the main ones that fail under a power surge/outage because they have a set of value assigned to them. The worst that can happens also is that a power transistor can go bad. The unit controls or regulate the power going in to the set.
So, if your TV does not turn on, turns but goes dean right after, or has the standby light flickering; you would need to have it check by a technician. On the other hand, you might want to check if its not just a reprogramming that the set needs.
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
1helpful
No power to control panel after power surge
Try turning the curcuit breaker off for a few minutes. Turn it back on and see if it resets itself. If not, the outage may have shorted out the main control panel.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
