Question about Bosch RS20 13 Amp Reciprocating Saw
How does one remove a broken blade from a Bosch rs20 blade holder
  • 35 Answers
Twist the collar around where the blade fits in the saw. It will lock in the open position. When you insert the new blade, do so firmly until the collar releases locking the new blade in place. Give a tug at the blade to make sure it is locked in.
Posted on Dec 01, 2008
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
I have a Bosch RS20 recip saw. A blade broke off in the chuck and I can't get it out. What should I do to get it out of there? Thanks for your help. Dan
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 17, 2010 | Bosch RS20 13 Amp Reciprocating Saw
Installing blade on a bosch jigsaw
The black part on top of the handle must be pulled directly up about 1/2 an inch. this engages the screw mechanism that loosens the blade. For some people doing this the first time feels like they are going to break the handle but it moves easier over time. Now turn the black handle counterclockwise several turns and the blade will hang loose in the holder. Turn the blade 90 degrees and remove it. Place a new blade in and turn back 90 degrees. Tighten the handle on top until it clicks. Align the black handle to the main handle and press back down into place.
Jul 15, 2010 | Bosch 1587AVSP Top - Handle Jig Saw Kit...
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
I hit a bolt and broke the blades. OK, I now have new blades. But I also broke the blade holders (chipped them where they also hit the bolt). I cannot find the part or its name. Blade holder? Just a...
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00701v-1.pdf
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00066v-1.pdf
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=1594K
The above three links will lead you to the Bosch web site, the 1594K manual which will describe the blade arrangements, and to the parts diagram that has the parts listed and their part numbers.
Hope this is of some help!
Aug 12, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
Rs20 bosch case falling apart
If you loosen the screws at the end of the saw that hold the boot on you can carefully snip the the rubber around the holes. This will alow you to remove the boot without dismantling the front of the saw. The boot is glued and they are sometimes difficult to remove.You can carefully take a flat blade screwdriver to peal the boot off and re-use it. Hope this helps
Apr 08, 2009 | Bosch Saws
Blade stuck in the chuck
If you have the lock released and can't get it out try pointing it towards the ground and running it. the piece should fall out unles it is still locked in
Nov 27, 2008 | Bosch RS20 13 Amp Reciprocating Saw
Bosch RS20 13 Amp Reciprocating Saw Logo
676 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
