Question about Hobart ET27 4-Slice Toaster
One side will not heat
Have a 4 hole hobart et 27 toaster replaced the elements and one swicth, now the other side will not get hot. Have switched sides with the control and the board in the rear and the left still works but not the right side
  • 41 Answers
Check your timer board at the back of unit
Posted on Dec 11, 2008
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
Right side only one heating element works very hot, when should the heating element be replaced.
You can repair the other side heating element in a electrical shop or by ur self if u have the skills. Mostly the element breaks of due to food hitting at it when ejected or inserted.
Thankyou
Appreciate a good rating from you.
Aug 01, 2009 | Toastmaster TP424 4-Slice Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
How do you replace the elements in a Hobart 4 slot toaster? I took off the bottom but there must be something I am missing. It's awfully small in there to manuever. There has to be a trick. Please share.
No Tricks. The elements are loaded and removed from the top.
DISCONNECT THE POWER CORD
Remove the crumb dtrawers, they are handy to put the parts on so the don't roll away.Remove the temperature knob after releasing the set screw, remove the lever knob after removing the pivot screw. Remove the 3 front and 4 rear cover screws with a philips driver. note the length of the screws from the locations.
Locate the element to change, disconnect the connections at front and back on the top of the element. With a small flat bladed screw driver, open the crimp tabs on each end of the bread guides and lift up. They come out of alignment holes in the lower frame. Replace the element/s, with the correct voltage replacement. 208 and 240 elements are different numbers. Reassemble in reverse order. Be carefull not to catch the element with the bread guard wires. It's common to see a bit of smoke during burnin of new elements for a short time.
Feb 24, 2009 | Hobart ET27 4-Slice Toaster
Toaster Parts hobart ET25-27
goto hobartcorp.com find your model then the part or call 18884hobart
Aug 14, 2008 | Hobart ET27 4-Slice Toaster
Need replacement dualit 2 slice toaster elements
You can get any part you need at the Dualit Repair Center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Jan 22, 2008 | Dualit 20247 2-Slice Toaster
Toast Master Toaster TP409
if you mean the toast itself doesn't toast on one side, check that both heating elements have about the same resistance value. One could be twice as conductive as the other and not heat as much as the other side.
If you mean the other two slots don't toast, the problem could be in the switch or in the elements themselves. check carefully the continuity of the toaster across the (unplugged) ac power connector while you push the toaster load handle down on each side. If the resistance is significantly larger on the problem side, the problem is either the switch or the elements. The problem is usually with the switch becoming corroded or oxidized. The switch is supposed to be self-cleaning, that is, it wipes itself as contact is made to help remove buildup. Sandpaper both contacts until they shine copper colored. Otherwise look at the elements while toasting. dark areas mean lower wattage is being dissipated and the element may be bad near a dark spot.
Nov 26, 2007 | Toastmaster TP409 4-Slice Toaster
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Hobart ET27 4-Slice Toaster Logo
228 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
