Question about Westpoint TV-258 Microwave Oven
Turning motor failing
Hi, I have the Westpoint TV-258 (claims to be 1,200 W) white microwave. I need some guidance on opening and I suppose repairing the turning motor under the microwave. Problem: The motor is sputtering and at times is making a noise. This is causing the tray to come off the gear inside the microwave. I'm assuming it's a matter of time until this only gets worse. Solutions? What do I need to know about being safe when working on a microwave and does anyone have any advice on this motor problem? Does Westpoint even have a website or documents? Thanks Jules
  • Westpoint Master
  • 9,098 Answers
It could be the motor failing (gears jamming due to internal damage or bad grease, perhaps) or the turntable coupler or support may have gotten warped due to heat. One test is to gently but firmly grab the coupler or turntable support and try to turn the motor. A good motor will offer resistance and "whirr" as you turn it. A bad motor will grind or click, etc. I would call Westpoint (see your owner's manual) and they can tell you if the parts are available and what they'd cost. Other listings seems to indicate this is an 800W microwave. And I would bet that parts may not be easily available. The turntable can usually be replaced from the bottom without taking the wrapper off. Once you've found out about parts availability, feel free to drop by my site (see my profile) to get my microwave safety and disassembly texts.
Posted on Jan 12, 2007
I need to get a replacement turntable for the TV-258 Microwave oven. Where can I get the part?
Contact the Microwaves support page on the internet and there you will find answers to this question.
Jan 30, 2015 | Westpoint Microwave Ovens
Hi I have a LG MG 583MC microwave, display,turntable is working, the oven does not heat up.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
If it's quieter than usual, it's probably a control issue, such as a bad door switch or mount, or a problem on the control circuit board.
If it's louder than usual or sounds the same, it's probably a fault in the high voltage section, such as the magnetron, transformer or diode.
Unless it is a convection type or is otherwise special, the average over the counter microwave is generally not economical to repair when high voltage parts or servicer help is needed.
Aug 22, 2011 | Westpoint TV-258 Microwave Oven
I need microwave oven with temperature control range of 0 - 50 degrees centigrade for checking of thermal stability of paint samples.
Microwave oven for checking stability of paints is not recommended as it would lead to explosion because paints are flammable. What you need is convection oven with fine adjustment. There are industrial ovens available for such purpose.
sonsunny
Jun 24, 2011 | Westpoint TV-258 Microwave Oven
The oven is not hitting up, the disc is rotating, inside lights are working.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Apr 22, 2011 | Westpoint TV-258 Microwave Oven
Need manual for microwave R-250A(G)M
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 06, 2011 | Westpoint TV-258 Microwave Oven
My microwace is out of order. No power in .I could not find the exact screw driver to open it at the back
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 01, 2011 | Westpoint TV-258 Microwave Oven
Microwave not heating food
Basic
heatman101
Feb 24, 2011 | Westpoint TV-258 Microwave Oven
Can i still use microwave if carousel does not turn but still heats food
You can but you may have uneven or hot and cold spots present in whatever you are heating. Sounds like the carousel motor has failed, those are replaceable. Good luck !
Jan 12, 2010 | Westpoint TV-201 Microwave Oven
Spare parts
go to appliance parts pro's website they're located in ohio
Aug 11, 2009 | Westpoint TV-258 Microwave Oven
Failed to heat food
I'd say it's a loose connection at the magnetron, a bad magnetron, or a bad high voltage diode.
If it's less than 30 days old, I'd contact the dealer to exchange it for a new unit or a refund.
If it's over 30 days, but less than the full warranty period, I'd contact the manufacturer (see the owner's manual) to get in touch with your nearest local authorized servicer.
Sep 24, 2008 | Westpoint TV-258 Microwave Oven
Westpoint TV-258 Microwave Oven Logo
130 people viewed this question
Top Westpoint Microwave Ovens Experts
William Miller
William Miller
Tom Chichester
Are you a Westpoint Microwave Oven Expert? Answer questions, earn points and help others
