Question about Teac V377 Single Dual Cassette Deck
Hi, can you please advise what configuration of tape selection buttons I need to utilise for playback of ferric tapes (not chrome)
4 Suggested Answers
  • 35 Answers
SOURCE: Correct Tape Selection button configuration on TEAC V377 Model
Ferric tapes use standard bias and playback. FeCr (ferric-chrome) use standard bias and chrome pb. Chrome tapes use high bias and high playback.
Posted on Mar 05, 2009
shibuda
  • 1812 Answers
SOURCE: Teac 4010s reel to reel. Playback drags and
Either take pully or cluch has been defected.
Posted on Mar 11, 2011
skywavebe
  • 1267 Answers
The A4010S is a Vietnam era deck and it is most likely to need all new rubber, Lubrication of motors and then the brake pads are known to fall off and jam- these I usually replace with fresh pads. The other possibility is the motor run capacitor has become defective. I change out the old with Metal Film types and they do work better then. I have had Sony decks do this same thing and the new capacitor (motor run) fixed it. These motors are in very bad need of good oil in the bearings. I have found that AMS signature synthetic oil has made new specs possible even on deck that could not get this low before. I had an A2000R measure at .02%wrms W&F.
Posted on Dec 21, 2017
Ho do i use the high speed dubbing feature to quickly transfer tapes to my pc using the alesis Dual-Cassette Tape Digital Archiver?
What's your hurry? You copy a tape once but listen to it forever in real-time without fear of it wearing out or degrading. Shouldn't it be as faithful a copy as you can get?
Downloads here:
http://www.alesis.com/tapelinkusb#
A little advice.... if you have any desire to transfer the higher frequencies from your cassettes to your digitized copies, do it at normal speed. The hi-end response of the deck is ok at normal speed but doubling it will double the playback frequencies, making incapable of reproduction with any fidelity.
Frequency Response
(-20dB recording)
Chrome tape 40-15000Hz (±3dB)
Normal tape 40-14000Hz (±3dB)
(0dB recording)
Chrome tape 40-8000Hz (±3dB)
Normal tape 40-8000Hz (±3dB)
Imagine what its response at, say, 30000Hz might be. That's what doubling the playback speed would demand from the head and electronics. It ain't hi-fi anymore.
Feb 13, 2011 | Alesis TapeLink USB Single Cassette Deck
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Hi8 tape only visable at fast forward/pause. Cam is good otherwis
i am trying to make a claymation but there is no pause button please help
Dec 08, 2009 | Sony Handycam CCD-TRV328 Camcorder
Rewind works, however I can't get the unit to play tpae
sounds like you nead to clean the capstan and rubber pinch wheel using a cotton bud and isoprenol alcohol. dip some of the alcohol onto the cotton bub and gently rub the little pinch wheel inside the tape compartment ( do not soak the bud and make sure the machine is turned off!) with gentle rubbing, ( try holding/stopping the rubber pinch wheel with one hand and gently rub the cotton bud on the rubber wheel whilst slowly rotating the wheel ensuring all sides of the wheel are cleaned ) and repeat this procedure on the little brass capstan that engages with the wheel. you will see some brown residue from the tapes on your bud...........repat this operation until no residue is visual on the cotton buds. Alao, do not use cheap ferric oxide tapes.......only use chrome types as they dont shed residue onto the machine parts! buy a demagnetizer and use once a month. it will make your machine sound like new. TIP; if you have no isoprenol alcohol use clear spirits like vodka or bacardi as they will do the job for you. good luck.
Sep 12, 2009 | Nakamichi Audio Players & Recorders
Nov 27, 2008 | Audio Players & Recorders
Cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Oct 25, 2008 | Sony Handycam DCR-TRV820 Digital-8 Digital...
Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Mar 04, 2008 | Canon GL1 Mini DV Digital Camcorder
Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 03, 2007 | Sony Handycam DCR-TRV250E Digital...
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Mar 25, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
