Question about Canon PIXMA MP760 All-In-One InkJet Printer
Colour faded I am having trouble with the colour of the prints. The colours a very faded and are not printing the right shade. eg red is like orange. I printed a top quality photo a couple of weeks ago, and not long after that I had to change some cartridges as they were low, and ever since then the colour has been right off. I have done a deep clean three times, and also printed out the test. The printer has 5 cartridges, a large black, small black, small cyan, small yellow and small magenta. The large black one is in perfect dark working order, and the others are very faded. Because the deep clean has not worked, could it be the printer head? If so, how do I go about getting one or having it replaced, and does anybody know how much something like that costs. Desperate for Help!!! Thanks
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Posted on Mar 28, 2007
SOURCE:
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
HP1600 colour fade on one side
it will most likley be the drum take it into a printer shop and they will clean it befor it gets to damaged as they are hard to replace
May 28, 2010 | HP LaserJet 1600 Printer
This printer has stopped printing reds and oranges correctly ? they are faded. Changed the toners & no difference
Print a "Config Report" from the printers menu...If u notice that the fourth square on the left side (fourth being the bottom square) for Magenta (reds and orange) is missing or very faded, this could indicate that the optical mirrors inside the printer have to be cleaned...Design flaw. ESP..if changing toners doesn't work and your your faded issue is with Magenta (Pink, red, or orange) colours are the only faded ones...With this design flaw in the optical mirrors, magenta mirror is the first to be affected!
Hope this helps!!!! I work in the industry :)
Feb 22, 2010 | HP Color LaserJet 2600n Printer
Canon pixma ip 4300 colour problems
If they are generic inks, sometimes the colors aren't quite right, also in your machine you can't use the photo inks, the photo magenta and photo cyan are not the right shade for your machine. You need plain magenta and plain cyan. Beyond that you may need a new printhead.
Oct 13, 2009 | Office Equipment & Supplies
All colours and black print faded. Black is a
ANSER #1
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
tanks.
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
Colour printing coming out with lines throughout print - shading
my color prints have proper colors but lines come through all through the print even using the best canon photo paper
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Colours are not correct on Kyocera C5016N
My Color is off My shirt is suppose to be bright BLUE and it is turquiose and the jacket is suppose to be RED and its Orange.
Feb 04, 2008 | Office Equipment & Supplies
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
329 people viewed this question
Clive
Clive
old marine
old marine
