Question about Sony VPL PX30 Multimedia Projector
Have a large yellow spot in the middle of the picture
Hi, I have yellow large spot in the middle of the picture. will my projector be expensive to fix ? james
  • 1 more comment
  • fredaaron Sep 09, 2008
    I am haing a Sony VPL-PX30 LCD projector with a yellow spot, I found that the Blue LCD LCX023CMT1 defective.
    Sony says to replace the full prism block p/n 175845911 which is very expensive.
    I think this is a common problem with VPL-PX30.
    I want to buy only the blue LCD if available. LCX023CMT1.
  • lldressler Dec 16, 2008
    We have a large yellow spot in the right upper corner or our picture.
  • dima5 Feb 26, 2009
    I have the same problem on mine as well. I don't think it's the prism block since the spot has pixelated (rough) edges. I think if it was the prism, you would get an out of focus yellow hue in the center. It might be the blue lcd panel driver circuit.
  • 2337 Answers
SOURCE: Sony 60" LCD projection TV has yellow screen discoloration
I would suggest to try to get this TV fix while still under warranty. Normally the manufacturers give one year.
In regards to the discoloration, there is not much you do but to let the Sony authorized repair center knows about it so they can fix it. Ask them if their work is guarantee as well for how long.
Good Luck.
Posted on Feb 25, 2008
  • 105 Answers
SOURCE: Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
Posted on May 18, 2009
  • 157 Answers
SOURCE: Two color variant spots in the middle of my Sony KV-34HS420 34 in
your tv needs to be degaused or demagnetised.it cant be a bad picture tube unless it was dropped.
you can call a local shop to degause it in your home.rather easy and inexpensive to fix.
Posted on Sep 24, 2009
rustym62
  • 201 Answers
SOURCE: yellow spot
Sounds like the optical block (the projector part of TV is failing) The block cannot be repaired it has to be replaced. It can easily cost several hundred dollars to fix. Sony did extend the warranty on some models, you can try going on their website to see if your model is covered or not. good luck!
Posted on Jul 04, 2010
  • 51 Answers
SOURCE: I have a large yellow spot on my screen..... Will
Your set uses red, blue, and green lcd panels to produce your colors. The lamp provides the illumination. What has happened is the blue lcd panel has been damaged in the area you are seeing the yellow. The fix for this is to have the optical block (also known as the engine) replaced. This is a very expensive part,... you may want to move on to a flat panel tv.
Posted on Aug 29, 2010
I have a large yellow blotch in the middle of the screen that will not go away. What do I do?
Sorry, your lcd on the Blue has burned, spare parts mean replacing the main optic combiner and lcd module that is more expensive than the projector is worth. it is dead, I have several similarly dead units.
Aug 17, 2011 | Hitachi CP-X1250 Multimedia Projector
I just replaced all 8 bulbs in my projectors. we are a large church and they are used quite a bit each week. when i tested them yesterday, one of my projectors had a yellow dull spot in the center of my...
Hi
If spot is light ( like a clouds ) then probelm is with dust .if is dark then LCD panel is faulty.pl conatc your nearest service centre
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | Sanyo PLC XF45 Multimedia Projector
I have a panasonic pt l500u, just started getting large yellow spot in middle of screen- looks like a giant finger print. Bulb was replaced less than two months ago.
Hi:
The problem here is the one of the miniature LCD screens in the unit is faulty, in this case its the blue one. There are three of them inside the unit RED<GRN<BLUE. The blue seems to be failing in your unit, for instance if you mix red and green you get yellow. Have a local shop service the unit and clean and refocus the unit back to factory spec's..
Nov 04, 2009 | Panasonic PT-AX200U Projector
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Green spot in middle of image as though a spot light was shinning on the screen. I've replaced the lamp
Welcome to LCD 101, the blue device is dying in the projector. Replace product with dlp brand and it will last a lifetime. good luck
Apr 14, 2009 | Epson PowerLite® 1700c LCD Projector
Sharp notevision xgnv6xu oval yellow spot
I have a similar issue with yellow pattern on the left and top right of my screen. Took it apart and found the blue lcd had damage that matched the yellow area that was projected. I thought it was the lens but it was the blue lcd .It has gone bad and no replacement. Are you interested in selling the bulb or the whole projector? I have since purchased another projector and am keeping the bad one for spare parts. Hope this helps..Ben
bgrenco@aol.com..
Jan 18, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Yellow spot
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
Oct 23, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Yellow middle, Blue Exterior
Hi Druaga
This is a Blue LCD Polarizer that will have to be replaced if the spot shows yellow.
You will find that this will only get worse as time goes by.
May 28, 2008 | Panasonic PT-AE700U Multimedia Projector
InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Mar 11, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Sony VPL PX30 Multimedia Projector Logo
231 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
