Question about Vanguard International Vx10TA Infra-Red Heater
I am not getting a red glow on all my ceramic plates .
What can I do to fix this problem?
  • 61 Answers
Most likely your thermocouple.
Posted on Nov 30, 2008
No heat in hostess trolley
Probability of the heating elements in ceramic plate and oven going bad at same time is really low. One of your 115 volt lines is not getting power to the plate nor the oven element which needs 230 volts (both 115 volt lines)..
Oct 08, 2016 | Kitchen Ranges
Where is the pilotless ignition located at
On the oven, it is usually attached to the back center of the burner under the over floor which can usually be removed. If you are asking about the top burners, the spark tip is right next to each top burner. The spark module that supplies the spark is usually on the range back, sometimes in the control panel area or just below it under a cover plate or box. Most ovens these days use a glow bar ignitor for the oven that glows red hot the complete time the oven burner is on. Looks like black ceramic and is very brittle if hit too hard.
Mar 31, 2015 | Kenmore Kitchen Ranges
I have a Gas glow warm heater with 5 plates 25000btus the three center ones are just burning blue with flames and the out side are still turning red. do i need to replace the 3 center ones or how do i fix...
Glow Warm is no longer manufacturer by the original manufacturer. It's not manufactured by FMI.
The burner may be bad and what you're seeing is the blue flames engulfing those 3 ceramic plaques. Or the burner may be clogged with dust, liny and.or pet hair and requires cleaning and servicing.
I have provided a link to the FMI Owners Manual page for your particular type heater, Check out the Trouble Shooting section, as well as how to clean the heater section, It should help you solve your problem.
http://fmisupport.hcents.com/supportdocs/WS%20125311-01A.pdf
Feb 11, 2011 | Heating & Cooling
Vanguard wall heater does not burn correctly
Hi the plates/burner needs cleaning out blowing then out with air line when off should help
Jan 26, 2010 | Vanguard International Infra Red - Medium...
Leviton rheostat switch has red glow inside
Change it out!!!!! Do not use. Could be a fire hazard
Aug 09, 2009 | Leviton Vizia Kit/Coordinating Switch -...
Top broiler igniter lights, but no gas is coming
The ignitor should glow almost white hot. If it is just red hot it may not be drawing enough amps for the valve to read and not allowing it to open and releasing the gas. It should pull 2.5 - 3 amps for the valve to open.
Aug 04, 2009 | Kitchen Ranges
Top burners work, oven not getting gas electronic ignition comes
The electronic ignition system (a ceramic plate that glows red) lets some power pass through to allow the gas to flwo when it has reached lighting temperature. The ceramic lighter needs replacing. Either that or the general electronic in the stove are shot.
Mar 11, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
The car started running extremely rough all of a sudden the cataletta converter is glowing red somebody told me to pull out the o2 sencers see if the car runs better if the converter was clogged but it...
If your converter is glowing it means that its clogged. You'll have to either replace it or break out the ceramic core. I'd recommend replacing it but this can be costly. To give it a quick fix you'll have to disconnect the converter and use a pry bar to break out the ceramic core, then reinstall the shell.. the down side to this fix is #1 emissions are higher #2 louder #3 may cause a problem with your O2 sensor....and may possibly be illegal
Aug 01, 2008 | 1993 Cadillac Eldorado
Neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
Jul 28, 2008 | Neff 23 in. T1443 Electric Cooktop
Vanguard International Vx10TA Infra-Red Heater Logo
95 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
