Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I have an RCA R52WH74 That when you attempt to turn it on the green light comes on for about 6 seconds then turn off if you hold the power button in it flashes 1-9 over and over what could be the problem
  • 7 more comments
  • bronx7_77 Dec 23, 2008
    My tv started cutting off about every 10 minutes for a couple days. Then it started working ok. One morning, about a week later, I turned the tv on; the power light came on for 5 to 10 seconds then went off. This happens every time I try to cut it on. It doesn't seem to want to power up. What is the problem with that.
  • mrseavann Dec 24, 2008
    when i cut my tv on it stay on for for a few second then cut itself off .
  • acefdc Dec 30, 2008
    We have this same problem. Our TV was working fine and then one day we went to turn it on and the green light came on for several seconds and then shut off-no picture or sound.
  • briancttrll Jan 17, 2009
    R52WH74 Model RCA HDTV turn on the tv the power light turns green then goes off comes on again then goes off does this three times no picture or sound.
  • Anonymous Jan 17, 2009
    I have the same exact problem. Green light appears but no picture. Green light will click off and then on about three times but the picture or sound will not turn on. Should i call a mechanic and if so, what will the mechanic replace and how much will it cost me?
  • joie2476 Jan 18, 2009
    green light comes on and than goes off again no picture no sound what should i do
  • adrian_baugh May 23, 2009
    My rca 52inch tv, when I turn it on , it comes on for a while then the screen kinda goes fuzzy but the picture comes back for a while , then it does the same thing again and finally cuts off. I attempt to turn it back on and it wont come back on , I usually have to wait to tern it back on.
  • ratherbgolfn May 11, 2010
    im having the same problem with my r52wh74 rca. where are these copacitors? in the tray on the bottom or on the panels on the back. also where are the fuses located.
  • bertavcox May 11, 2010
    where exactly are these fuses located
  • RCA Master
  • 5,138 Answers
Replace 3 capacitors cp150 2200uf 16v If it is puffed up on top it is bad ,need to replace 2 more caps cp120 cp114 220uf 35v they are green with gold writing on them.
Posted on Dec 25, 2008
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
TV does not power up
I have mits 35" CS 3505 will not turn on... just turned off and thats all she wrote,,, what is the estimate cost of the deflection circuit board
thanks
artie
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
When I push the power button on my RCA HDTV R52WH74, the green light turns on for about 5 seconds and then off. NO sound and no picture.
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
Jun 24, 2009 | RCA R52WH73 Projection Television
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
RCA R52WH74
the 3 blinks is definately meaning the flyback is defective. You need to replace the flyback its number 259296 you can get a replacement flyback at the following link with free installation instructions with step by step pictures of the repair. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | RCA P52937 52" Rear Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
688 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
