Hi, I had upgraded my Laptop and already installed the XP Pro OS on my it. I have a router at my home and I need the appropriate drivers for wireless. Where can I find them? My Laptop is Extensa 5024 WLMi. Kind Regards, Orna
You can install xp on a vista laptop, you will need an xp install cd and you will need to backup your data (it will be erased in the downgrade process). As for the drivers, go to your laptops manufactures site. They will have a support section for your laptop model where you can see if there are drivers for xp. If you have the hardware that will support windows 7, I would go with that. Xp is slow and no longer supported by Microsoft as of April 2014, which poses a security risk. Windows 7 will be supported for a while and is faster and more stable than xp or vista.
Home Edition is already a version of XP. XP was released in Home and Professional versions. You can find out for sure what version of software you have by right-clicking on the desktop icon for "My Computer" (or on the "My Computer" entry on the Start Menu if the icon is not on your desktop), then clicking on "Properties" from the popup menu.
If you want to upgrade from XP Home to XP Professional, you can do that with the appropriate upgrade CD. But unless you are networking in an office setting, there really are no features in Pro that you don't have in Home.
If you still have questions, please post a follow up comment and I will try to help further.
All you need to do is insert your Windows XP disk at start up and boot the disk by pressing any key when prompt to. Then run a clean install since a upgrade will not be available. You may want to backup your programs e.t.c.
Regards
If your home network is a typical network with a basic consumer router and PCs you'll require a new router or firmware update, as most routers currently only support IPv4. Installation of protocols already built into Windows XP, Windows Vista, and Mac OS X. Windows Vista and Mac OS X already support IPv6 natively and Windows XP only requires the addition of an IPv6 protocol driver. It's possible to run IPv4 and IPv6 on the same systems on the same network without problems.
Because TCP/IP operates lower layers of the "OSI model", the vast majority of software applications will work perfectly without modification. Only software that makes changes to or makes direct use of lower-level TCP/IP functions will need to be replaced and this is somewhat rare.
Geek Squad Agent Erik, Badge #2555 Geek Squad Secret Weapon Go ahead, use us
HI , Listen dear compaq c700 models does not support windows xp , so i suggest you to please install windows vista home basic minimum.... all the drivers needed by this os is available on www.hp.com..... hope you must be satisfied otherwise no solution is dere.... b.bye
