Question about Amana SXD524VW Side by Side Refrigerator
Amana fridge SRD27S4W 27CU.IN. 1995 S/S PARTIALLY COOLING
AFTER 12 HOURS SHUT OF, IT STARTED WORKING ALLRIGHT IN ABOUT 10 MIN. WE R TRYING TO CLEAN IT UP AND RESTART AGAIN. IF IT WAS DEFROST TERMOSTAT PROBLEM WE SHOULD NOTICE THE FROST ACCUMULATION AT THE BOTTOM OF THE FREEZER. DO YOU KNOW THE SITE WERE I CAN GET THE PART AND STEP BY STEP INSTRUCTION TO INSTALL?
    President:
  • Amana Master
  • 2,651 Answers
Normal to have frost accumlulation, on the evaporator coil, not normal to see it coming thoughthe back panel, which is indictitive of defrost prblem, you can remove the back panel inside freezer compartment and look forthe thermostat( 2 wires leading to a round thermostat clipped onto the top coil of evap, simple to replace simply cut out old and wire in new one heres the part number R0161087
Posted on Dec 02, 2008
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
Jenn air refrigerator jcd2389ges freezes fridge
Bea, try this. UNPLUG the refrigerator for 12 hours and keep the fridge and freezer doors open. You might lose some food. NOW you will find some water under the fridge. clean that and now power up the fridge. Make sure you hear the motor working. Your fridge will start cooling. Keep at recommended temp.
Mar 07, 2014 | Jenn-Air JCD2389G Side by Side...
Freezer blowing air but getting warmer and stopped making ice. Fridg also seems to be warming up. no unusual noise.
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. But if the freezer also gets warmer it can be failure of the auto defrost making the vents choked. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 20, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
For Samsung Refrigerator SR-L629EV my freezer
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Jan 05, 2011 | Panasonic Microwave Ovens
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
CONSTANT CLICKING SOUND COMING FROM POWER BOX
if the fan blade is contacting anthing under there and stops it will shut down the compressor and wont work
After moving fridge (and waiting 36 hours) compressor won't start
You should worry , the 12 amps is a locked rotor on the compressor , it may be the over load relay control on the compressor as well , try replacing the over load start relay first , they are not expensive , if this does not fix it you can try installing a booster like a rco410 but the comp. can not take that abuse for years from the booster. when the comp. is running normal it will draw roughly 1.5 - 3.0 amps.
Phil
Apr 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
196 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
