Question about HP iPAQ RX3715 Pocket PC
Rx3715 several problems
Hello,i own a rx3715 and facing some problems. 1 the battery is displayed as unknown in the battery status menu, no level of charge no nothing. When connected to the charger there is no led flashing, amber light or anything. Also, is it normal that the pda can power on using only the charger, with no battery inserted? Other ipaq's don't do that from my experience. 2 the sd card (any sd/mmc card inserted) works very slow, it also slows down the pda very much. It takes about 10 min to copy a 3 mb file from another location to the sd card. 3 the pda doesn't always power on from the power button. To power on i must make a soft reset. I think those problems are somewhat related each other. After a ROM update they still remain unsolved. Also I do have some other questions about rx3715. Is it possible to install wm5 on it, where can it be found? Are there any programs to improve the camera performance?
  • Motoi  Bogdan
    Motoi Bogdan Jan 15, 2007
    What problems do you have more exactly? Is your rx3715 using the original battery? And how did the problem occured to you. It will be helpfull to me to figure what is rong as I have experience with pda's but this problem is pretty odd to me.
  • Motoi  Bogdan
    Motoi Bogdan Feb 02, 2007
    :) I was shure I was facing some serious problems but as a guy with experience over these things I figured out, after the dissasembly and the ROM upgrades, that the problem isn't software nor hardware related, somewhere between - the firmware. A ROM update doesn't replace the PDA's firmware so the problem can't be corrected by these methods. Sometimes the card is more faster, sometimes is not, the battery isn't displayed most of the time and no leds are flashing altrought the charging circuitry is ok.
    Therefore my question is, is there a way to upgrade the firmware for this device? Not a ROM updade, a firmware one.
    Problem Solver:
  • 15 Answers
If you have only flashed the English ROM, not any other language ROMs, read the following paragraphs. If you have flashed other language ROMs but not the German one try flashing the German one instead, there is something about it that clears the ppc out better. If you have flashed the German one, do not read on, as it will be an insult to your intelligence.
Most problems can be fixed with a ROM correction. Unfortunately, this is unachievable by simple re-flashing the English ROM. Certain other versions of the ROM (usually German is used) contain different enough sets of code (possibly different firmware?) to force the ppc to truly reset, unlike what happens when simply flashing the US ROM or changing to ROMS that use similar enough coding. Try flashing the German ROM and THEN reverting to the English. This tends to solve most any major iPaq issue.
Refer to
http://www.fixya.com/support/t395941-display_operating_difficulties
For full instruction.
Posted on Mar 01, 2008
How do I reset the fuser AND PF (PAPER FEEDER) part life
1) Press the 3 and 9 buttons at the same time in the ready status.
2) "Reset Menu" will appear on the LCD. Scroll to Fuser by pressing up arrow or down arrow button then press the OK button.
3) "1. Reset 2. Exit" appears on the LCD. Press the 1 button to reset the fuser counter. The display briefly shows "Accepted".
The machine returns to the ready status after a few seconds.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 07, 2014 | Brother MFC-9120CN - 17 PPM Multifunction...
Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Sep 23, 2009 | HP LaserJet 2840 Printer
How do I check to battery charge level on my raozr
1 Menu 2 Settings 3 Phone status 4 Battery meter That should do it!
Jul 13, 2009 | Motorola Mobility RAZR V3
Printer replaced with black cartridge, and doesnt print
Hello sir; did you remove the tape sealed on the black cartridge, make sure your cartridge is OEM not GENERIC.
Feb 03, 2009 | HP Photosmart C6100 All-In-One Printer
JVC av-32220 television focus problem
Kindly use the link to solve you problem. this is the service manual for your JVC TV. Kindly download it for future ref.
http://www.manualscenter.com/manuals/jvc/av32220-service-manual.html#.WQMgJYVOKsA
Apr 28, 2017 | JVC AV-32220 TV
Connection status unknown & Firewall couldn't be switched On
Dear Customer,
you have to activate your windows firewall than that red cross icobn will remove from your right side taskbar,]
1,first go to control panel than open windows firewall programm
2.than you can find to radio button 1 is green colored for activating & 1 is red colored for deactivated ,now you have to reactivate your firewall than you can remove your message from your taskbar,
do it & run safely your windows,
THNX
May 18, 2008 | Compaq Presario 700 470024-192 Notebook
Numerical time versus clock icon on the status bar
touch the clock icon and hold it down. A menu will pop up. Select digital.
May 07, 2008 | Palm Treo 700w Smartphone
Ink problems col vol unknown and wont print
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Jul 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
IPAQ RX3715
The only answer that I know of is third-party software. I have a battery monitor program that puts a battery meter down there, just like what you want. It's called "BatteryWatch 1.02" and I got it from pocketgear.com. Here's the url to the download page: http://www.pocketgear.com/software_detail.asp?id=2586 it's FREE. :-)
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
428 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
