Question about Heavy Duty Stanley Bostich Heavy-duty Sharpshooter Electric Staple/nail Gun
Bostich nail gun plumger not retracting - Heavy Duty Stanley Bostich Heavy-duty Sharpshooter Electric Staple/nail Gun
  • David Ford
    David Ford May 11, 2010
    Did you get the problem fixed? If not let me know and I will try and help. I work on them for a living. If you need me please also have the model number so I can figure out what parts might be needed
    Sergeant:
  • 359 Answers
Spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Posted on Dec 03, 2008
What size nail i need for stanley Bostich nail gun n65cp?
The gun uses a nail set at 15 degrees that has thin wire connecting each nail together.
Mar 05, 2015 | Stanley Air Tools & Compressors
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
Jan 12, 2015 | Heavy Duty Stanley Bostich Heavy-duty...
I have a 16 guage Bostich nail gun that has worked perfectly with the nails supplied with the gun. We purchased more Bostich nails and they are making a U-turn in the wood and coming back out. This is...
I would check first for the proper guage nails that you bought and then what is the capacity of the tool. You didn't specify the model number but I would think one or the other. then also check for the wood being nailed into. All could lead to your problem.
Feb 20, 2011 | Air Tools & Compressors
Having problems with the gun not pulling the next nail, the thickness of the wire between nails sticking in gun and then double shooting. using gun in new england, its cold we warm it first. any...
Nail feeder on this gun is both air and spring controlled. Air pressure retracts the feeder and a strong spring pushes the feeder back to front. Remove nails and leave side door open. Dry fire gun very rapidly against thick rubber pad and watch the feeder retract and return. It should move very rapidly all the way back and front again. If it appears to move slower than piston is moving then follow next step. Pull the feeder back manually with tip of screwdriver. It should be very hard to overcome spring. If spring feels strong then suspect feedpiston oring or air supply to feedpiston chamber is restricted with debris from inside of the gun housing or air is leaking where body of gun mates with lower nose. There is a small white oring that seals between body and nose base. Sometimes this oring will be over-compressed thus restricting air flow into feed chamber. Remove two allen screws at front of base to split body from base and reveal this oring. Parts are available at www.toolpartsdirect.com. Good holidays
Dec 25, 2010 | Stanley Bostitch Rn461 Gun Coil Roofing...
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
Roofing nail gun will not cycle- blowing air out around trigger area-Stanley bostich
you need a new trigger assembly TVA6 or if you have a local repair shop they might just have the o ring that is split.
May 23, 2010 | Stanley Bostitch Nail Gun
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
I have a bostich framing nail gun and as soon as i hook my air hose up to it the air comes directly out through where the driver is, dont even have to pull trigger, can u help, need gun operating to make...
The o-rings need to be replaced and/or the trigger assembly is defective. Look around at local lumber yards for a "Bostich days" promotion. Often with the purchase of a box of nails, the Bostich rep will "service" up to 2 guns for free. If this is not an option for you because of time, you can purchase the o-ring kit and replace the rings yourself. This is not a difficult repair. Also, be sure to lubricate the guns with pneumatic oil frequently as this will keep the rings lubtricated and prevent them from drying out and leaking.
Hope this helps,
Dan
Nov 30, 2008 | Stanley Bostitch F21PL Nailer
Heavy Duty Stanley Bostich Heavy-duty Sharpshooter Electric Staple/nail Gun Logo
187 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Paul Carew
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
