Question about Kitchen Appliances - Others
IGNITION WITH PROPANE DEEP FRYER
I HAVE A DEEP FRYER THAT I AM HOOKING UP TO A CANISTER OF PROPANE. I HAVE ATTACHED THE CANISTER AND TURN IT ON BUT NO FLOW OF PROPANE TO IGNITE THE DEEP FRYER. THE PRODUCT ID UNKNOW BUT IT SAYS metal fusion, inc on the side
    Genius:
  • 1,199 Answers
This is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Posted on Dec 06, 2008
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
What is the cost involved to change from gas to propane on a deep fryer
I'm not sure how much will it cost to convert a fryer from propane to natural gas but you will be needing a conversion kit in doing this. Try to visit pitco website at www.middleby.com and look for the nearest distributor on your area.
Jan 18, 2011 | Pitco Frialator SG14 Deep Fryer
Hi I have got a cecilware deep fat fryer
Sounds like you need a gas regulator in the main line.
Either that or you are using a natural gas fryer on propane which is a no-no if not converted properly.
Dec 20, 2010 | Cecilware FMS-40 Deep Fryer
Flame not going into heat tubes
Make sure the regulator assembly on the gas valve is for propane. Sounds like the gas pressure is too low and the flames aren't going into the burner tubes. Make sure they didn't install an appliance regulator on the back of the fryer. This is not needed as the fryer has a regulator on the gas valve. You can unscrew the cap on the regulator assembly and turn the plastic screw inside all the way in. DO not turn with alot of force. Easy does it.
Tom
Jul 23, 2010 | Imperial IFS40 Deep Fryer
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Frymaster blowing back fire
google sams manuals.is your fryer propane or natrual gas if so the baffles and orfices in the fryer are clogged.propane burnes very dirty.
Aug 12, 2007 | Frymaster Dean 2424G Deep Fryer
Kitchen Appliances - Others Logo
232 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
