Question about Delta Commercial 400-WFELHHDF HDF Series Single Handle Kitchen Faucet w...
Single handle Delta Kitchen Faucet
The handle will only shut the water off when it it is on the right side. This would normally be the position for cold water. I took the small red/blue cover of the set screw to try and adjust the position. Now the water shuts of in the right position but at the top not bottom. Please help. Also how does the tap come apart to get at bthe cartridge.
Thanks
John
  • 334 Answers
The red/blue cover just hides the screw that allows you to remove the handle.
Turn off the water :-)
Remove the handle, you will see that part of the faucet is a large half moon nut. sometimes you can loosen these with your hands, but most times you will need a tool. To avoid damaging the finish with the tool, use smooth jaw tools or protect the nut with a thin piece of rubber/cardboard etc between the jaws of the tool and the nut.
You can then remove the ball/stem, the washers and springs.
Replace the stem, washers and springs and reassemble just as you took it apart.
Be carefull that the little "nipple" lines up with the notches properly.
Take care that you know exactly how it came apart and which direction each prt was facing.
Posted on Dec 06, 2008
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
Mar 25, 2013 | Delta & Single Handle Shower Faucet
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
I have an older single handle Delta shower valve, and I am only able to get good water pressure on cold water (which is opposite of the normal right hand). Can you suggest a solution?
A rebuild kit for a shower is pretty cheap for delta. the actual ball behind the handle maybe wore and not allowing it to seat properly and restricing water flow hot side.
Also if you take it appart the 2 washers and springs you might as well replace them also.
Replace washers and springs and the ball with shaft that handle fits to.
Shut off water before taking appart.
May 07, 2010 | Delta & Single Handle Shower Faucet
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Vegetable Sprayer leaks when faucet is turned on....is there a repair kit for it??
there should be, probably a diverter problem inside the spout assembly. It is stuck between settings letting water travel through the hose and out the sprayer. It is not returning fully to resting position.
Oct 24, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Valve in Delta faucet closes as water warms up
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Jan 10, 2009 | Delta Faucet Delta 156-WF Victorian Single...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta Commercial 400-WFELHHDF HDF  Series Single Handle Kitchen Faucet w... Logo
146 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
