I have tried to turn on the A/C, and it still continues to blow out hot air as if the thermostat was turned up as hot as it will go. Have not been able to find any blown fuses. Is there a separate thermostat, other than the engine, for the heating and cooling system? Could the knob be stuck?
SOURCE: Heating system only blows out hot air through the vents
I would look at the air blend doors first, it sound like they are not working or your control in the dash is not working send a signal to them. they work by changing the air from hot to cold or in between.
Avalanche, Sierra And Silverado
To install:
C/K Series
To install:
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
