Question about Sony KP-61V90 61" Rear Projection Television
Where the conversion chip located on the 5 jcv tv.
Colors and shadows and top loops down in picture I want to replace my conversion chip on my t.v.
    Sergeant:
    Champion:
  • 346 Answers
The convergence chip is written stk392--- for example
THESE ARE ICS .BLACK IN COLOR AND IS MOUNTED ON METAL HEAT SINK
Posted on Jan 02, 2009
I left my 60 inch rear projection mitsubishi HD 1080 on overnight as I fell asleep in front of it for about 5 hours (11pm - 4am). This morning when I turned it on the picture is doing a fisheye effect on...
It sounds your Mitsubishi rear projection tv got problem with convergence output chips failure, I'm not aware about model number of this tv so unable to provide you specific info however, it is hardware failure and few parts need to be replaced by tv repairman.
Convergence output chips make align picture on front screen and if they stop working, you will see 3D look or bowed picture with different colors.
Contact local tv repair shop to fix this issue in tv.
Thanks.
Nov 17, 2010 | Televison & Video
Shadow of colors of picture in 3 D
This set uses two STK--392-110 ( you can also replace them with STK-392-150 which is a upgrade for the original type convergence chips)----You can buy both on Ebay for less than 13 dollars plus shipping2.gif.
Both chips need to be replaced and any damaged resistors around them located and replaced also--most of the time the set just needs both chips replaced and then adjusted.
If you cannot do this repair yourself--look in your area--most shops TRY to charge 300-400 for this kindof repair----I do lots of them here--did two Hitachi2.gif sets with this problem yesterday for 200-250 total.
MAKE SURE WHOEVER you get to do this changes BOTH CHIPS--SOME techs will come out and just replace one--in a short time the set will have the same kind of trouble again---Now is the slow time of year for TV repair shops---shop around for someone who will do this repair IN YOUR HOME--almost any good tech can do it in about 1 hour---if they say it "has to go to the shop" keep looking.
The chips are black(2 1/2 inches wide and about 1 1/2 inches tall with 18 pins) and will have the STK number printed on them in white--they are located on either one large metal heat sink2.gif with fins or two smaller heatsinks2.gif that are side by side.
If you have ANY questions or need help reply to this post here.
SD TECH
Oct 18, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
A transformer blew in our neighborhood and now our tv picture is bowed and the colors are shadowing one another
Your conversion IC's are out, they cost about 40 dollars for 2, if you know how to solder, you can change them yourself, otherwise, repair shops usually charge 4 or 5 hundred
Jan 08, 2009 | Televison & Video
Blue Shadow
YOU CAN TRY TO ADJUST THE COVERSION POINTS USING THE MENU OPTIONS IF THIS DOES NOT WORK THEN YOUR CONVERSION CHIPS HAVE TO BE REPLACED IT COST AROUND 200 TO 250 DOLLARD
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
SHADOW EFFECT
sounds like the conversions is out you maybe able to resit the conversions in the menu or you will have to replace the ic chips. now if you have a DLP set you can not do this and you may need a digital board.
Jul 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Horizontal bow and shadow
Replace convergence IC's--then re-check convergence alignment in servicer mode,if necessary.
Sep 27, 2007 | Philips 9P5544C 55" Rear Projection...
Sony KP-61V90 61" Rear Projection Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
