Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
We have a kitchenaide dishwasher and the clean light keeps blinking off and on and the dishwasher won't work. Of course it is Thanksgiving and I have a house full of people coming over! Any ideas? Thanks!!!
  • 2 more comments
  • Anonymous Jan 02, 2009
    Same problem. Clean button flashes 7 times, pauses, then flashes again. Repair person charged me $174 in labor to replace the control panel which is under warranty. He said it was working and left. I tried to start it and the clean button still flashing and doesn't work. I will post when it is fixed
    ssame problem with the flashing clean light.
  • Anonymous Feb 15, 2009
    My kitchenaid dishwasher flashes clean.It is empty and I want to load it to do another load.I tried hitting the start button to do another load and it is stuck on flashing green.Any ideas? Thanks in advance.
  • misfitsink Feb 15, 2009
    "Clean" light flashes. Dishwasher will not operate. Kitchenaid rep suggested heating element is burned out, but the unit is onlt two years old.
    Sergeant:
    Champion:
  • 291 Answers
You can try to kill the power to dw and with 15 minutes before supplying power back and see if it will reset your control, if not you will need a new control board / thanks
Posted on Nov 27, 2008
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light keeps blinking and washer will not function. Cancel runs the pump for 2 minute, but the blinking light keeps going with no functions working.
if the clean light is blinking that mean you dishwasher is having a heater issue. it is an error code. either your control board is bad or the heater or the ntc therm. if you take the bottom panel off you will see or should see a tech sheet that will tell you how to clear the error code or this website will help you. just enter your model number http://servicematters.com/docs/wiring/wiring_main.htm
Jul 03, 2010 | KitchenAid Dishwashers
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Feb 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
230 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
