Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Freezer works 3 degrees; refrigerator does not 75 degrees
Have a two year old Maytag French Door Model: MFD 2561 HES
Some suggest that a flapper may be stuck, there may be a second fan for the refrigerator not working.  I cleaned the dirt from below the unit, it was not that bad.
I have not gotten behind the unit as yet.
    Sergeant:
    Champion:
  • 291 Answers
Your freezer has a dc volt cont motor in back and they will quit from time to time and will need to be replaced / move freezer out and pull off back cover and check to see if motor is running, if not set a small fan behind to blow air on unit till it can be replaced to get temp back ,,, if that isn't the problem contact me with more info and i will be glad to help you / please remember to leave a rating / thanks / larryyb
Posted on Nov 27, 2008
  • Maytag Master
  • 19,396 Answers
  • Ginko
    Ginko Nov 27, 2008
    Check also that the re is no ice on the coil at the back, when you get insufficient cooling on the fridge, this is often because of the evaporator system located at the back of the fridge, or a problem with the condenser.
    Try performing a complete overnight defrost, and then cleaning all the coils at the back and at the bottom of the fridge from dust or dirt.
    Often the problem disappear after cleaning and defrosting.
    If this does not work, then there is probably a fault concerning the evaporatior system.
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
May 29, 2013 | Maytag MFI2067AES Stainless Steel Bottom...
Maytag MFD2561HES Freezer Door Locked, How do I get it open?
Hi and welcome to FixYa, I am Kelly
Here is the users manual that is probably inside the door you can not get open:
https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
Find your model number and download the maual. The last 3 figits HES there is a problem with the number you passed. I am using this manual as a reference:
https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10175446.pdf
If your unit has the mini handle on the top right or top left gently lift and swing the door open. If you have the lone horizontal handle on the front of the freezer door it just pulls open and slides out.
If this is a NEW unit... you must remove the shipping tape from the door (2 to 3 places) to get it open.
Thanks for choosing FixYa,
Kelly
Jun 27, 2011 | Maytag MFD2561HE Stainless Steel Bottom...
I have a Maytag model MFI2568AES french door bottom freezer refrigerator. I have had problems with the control panel not working. We have been able to get ice but could not switch to water. Now i cannot...
don't think you need a new unit . and most of use like the service . the filter does not prevent the ice maker from working . but the water valve does and the tempt in freezer must be 15 deg or lower . ck your fan inside and underneath. both muts be going . hope this helps mm .. and ck with another service theat will be helpfull. mm
Aug 01, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Unable to adjust temperature,food freezes even at 6 degrees It is a new Maytag mfi12266aes
Good day,
If it's new (under one year old) then all components are under factory warranty. Call your selling dealer for a warranty service call. It should be free.
Apr 10, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
Water dispenser not working in my Maytag Model #MFD2561 HES
Hi. Do an Internet search for Maytag recalls. Your fridg. may be on their list. If this solution has assisted you, please rate it. ricardok45.
Dec 27, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
29 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
