Question about HP Photosmart 8250 InkJet Printer
Black ink is not being being printed out to paper
All inks have been replaced and the headh have been cleaned several times
The test that shoulkd be black is coming out red
  • 98 Answers
It could be that you have the ink cartridge in the wrong slot/spot, or there is something blocking your black ink from getting to the paper.
Posted on Nov 27, 2008
  • HP Master
  • 19,396 Answers
That means that the print head is clogged or faulty, you nead to remove the printhead and clean it, or replace it.
    Sergeant:
    Champion:
  • 304 Answers
Try to clean the print head, using the utility software install on your computer.
  • Elizabeth Krijt
    Elizabeth Krijt Nov 27, 2008
    Print heads become blocked for a number of reasons, but the most common is simply that the ink cartridge has dried out, and so has the print head. Anyway, here are a few hints and cleaning methods that MIGHT get things working again.
    • Never let the printer stand with an empty cartridge. Either fit a fresh one, or seal the print head unit in a plastic bag with a few drops of water for humidity.
    • If the print head has become clogged and the printer's head-cleaning cycle won't help (run it 10 times if you have to) you could try these things:
      • Soak the print head in hot water then leave it overnight, then try it again
      • If you have access to an ultrasonic cleaner that will take the printhead, use that. (These are used by jewellers and other people which have to clean small, intricate parts)
      • Buy some Isopropyl Alcohol and soak the printhead in that overnight. (You can get it from the chemist)
      • Use a Mr Cuppacino (or your Espresso machine). It's a small kitchen appliance which creates a jet of steam for frothing milk for making a cappuccino. You can use the jet of steam to blast the print head. But be careful that you don't melt things -- short, sharp jets only.
      • Each time you try a cleaning method, use a damp paper towel to gently wipe and dry the print head area.
      • Put a teaspoon of water in the bottom of the empty cartridge and try the cleaning cycle a few times.
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Canon Pixma MP800 Prints a 1/4" black stripe on back of page. Is emptying the large PGI-5 cartridge in record time. Have replaced cartridge, run cleaning and maintenance routines. Cleaned bottom...
I have seen this before but it has not caused the black to run out quickly. if you look into the machine you will see at one end of the platen roller it will be swimming in ink. As the paper passes over the roller it will deposit ink to the back of the paper. now why is the ink getting there? Well its just possible that air hole in the cartridge is blocked but you say you have replaced the cartridge. Ah but with what? are you using recycled cartridges? they may be filled with ink and not dye which is what originals use. Dye is much thicker than ink and ink maybe leaking from the cartridge. The seal in the carriage may not be making a clean contact with the base of the black cartridge causing it to leak when the carriage is moving. Check those out and repost if still having the problem.
Good luck
May 16, 2011 | Canon Office Equipment & Supplies
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
Changed new ink but when i print, the pages come out blank with no ink. Printing motion takes place but some how the ink done not reach the paper.
I had the same problem with my DCP 165.It simply wouldnt print.The paper was coming out but it was Blank.I had changed all the cartridges so there was no obvious issue with the ink.Then I printed a test page.It printed all the colour blocks except the black.Then i found out from Brother website that it was a problem with cleaning and after seeral cleaning cycles the printer worked fine. STEPS 1>ink management 2>Cleaning 3>Black or colour 4>OK Repeat the above process several times and try printing after that...Hope it works
Sep 15, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Aug 17, 2009 | Brother Multi-Function Center MFC-240C...
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Black ink not printing
To fix this problem I installed a new driver and switched the paper settings to high glossey paper...so far it works...black was the only problem...color printed fine.
Dina
Nov 22, 2007 | Epson Stylus C43SX InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
