Question about Lexmark Office Equipment & Supplies
When i try installing my 4650 it stops at not enough memory, but i am sure i have enough memory. do i have to put an external memory stick on?
  • 47 Answers
Have you tried this? when the window tells you that there is not enough memory comes up, press ctrl+shift and close the window. sometimes install continue.
Posted on Nov 27, 2008
I have just brought my 1st memory stick how do i put stuff on it to transfer to another item
Treat it as though it were an external hard drive.
Your computer should recognise it as you plug it in.
They normally come formatted, ready for use.
Jan 31, 2011 | Computers & Internet
Wharfedale DVD1100 PLayer does not detect USB Hard drive
It's unlikely that you're doing something wrong. Did you buy this DVD player as one that is supposed to support connecting hard drives? If not, then the player probably doesn't support connecting a hard drive.
Jan 08, 2008 | Wharfedale DVD-M3 DVD Player
Trying to install Dynes 5 in 1 memory card reader/writer on my Mac running 10.6.4 Can I put the small disk in my laptop drive - it is a slip in slot
If you're worried, put the small CD-ROM into some other computer, and copy the entire contents to a full-size CD-recordable disk (or to a USB memory-stick).
Then, carry the CD-R (or the memory-stick) to your computer.
Dec 20, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Hello! Here is my problem; I have Gateway MX6426 laptop and CD drive went off. When I try to install Windows XP from external CD drive some problems occurred. I put CD in ext.CD drive,run clean...
Press F1, ie for Gateway to enter Bios settings.
Go to your BIOS MENU,
From "Boot options" set 1st boot to "removable drives" save the setting, ie if you are using an external CD/DVD or USB flash drive. If you are using an external CD/DVD Rom, ensure that the power supply to the external CD/DVD Rom drive is sufficient.
Try and reinstall the Operating System again.
Hope it helps, and good luck.
Oct 11, 2010 | Computers & Internet
Install xp on the d845 p4 motherboard w/2.0 chip it stops on inst
Windows XP requires a lot more memory than Win98, at least 128Mb. Problem will either be not enough memory or faulty memory. If there is more than 1 stick of memory try using just 1 stick at a time until you find the faulty 1. If theres still a problem try to include a bit more information as to your memory configuration and when you say it shuts down is it coming up with a blue screen? cheers from Scott
Feb 22, 2010 | Intel D845GVSR Motherboard
I was scanning documents 8.5x11 into memory stick using microsoft word just stopped error came up 3015 hp laser jet all in one it scans otherwise except to microsoft word
Next time do not scan directly into an external memory device. Scan first into your hard drive and then copy/move it into your external memory device. It puts a kind of stress on the system; it is processing and copying at the same time.
Seems the stress has broken down your memory stick. To confirm if your memory stick is fully functional, check to see if you still see its icon under My computer. If you do try to copy any file into it. If it copies successfully, it means it is still OK. Then scan into the computer first then transfer into your memory stick. If however, it fails to copy, it means the memory stick is affect. Then you need to know to what extent? At least you need to know it you can recover your memory stick.
To do this, right click on the memory stick icon (under My Computer) and select "format." The Format dialogue box pops up. Format the memory stick. If it formats successfully, your memory stick is recovered. But it fails to format, you have lost your memory stick.
Dec 07, 2009 | HP PSC 1350 All-In-One Thermal Printer
Can't save music to external memory
ive been trying for ages to do this and its so easy but no one seems to be explaining it easy! Your phone without the memory card only holds one or two songs. you must have songs in there for it to say memory full. Go to this song press options , file, move to extrenal. Now try and send a song through bluetooth. You will be able to recieve it now you have freed up spave on the phones own memory. Remember to save it to external straight away so u can recieve the next item. Easy peasy!
Aug 21, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Pc don't recogise new hardware
It sounds as if your power supply isn't putting out enough to support so many USB devices on your system. If you have an external USB Hub, do you have a power adapter plugged into it?
Mar 28, 2009 | Computers & Internet
Can't get to where I put in the product key
get it downloaded/copied to some external storage eg. memory stick(you must be having USB at least) and install
or
get borrow external CD-Rom, may be from your friend( if anyone has) and get installed.
Rate me Fixya :-)
Thanks
Mar 26, 2009 | Microsoft Office Professional 2007 Full...
Does not read my Memory stick any more
Hello Cbaltzer,
Try to use in another PC, your memory stick, and see if work, if so, perhaps it is a problem with your other PC, or the USB port, see if is 2.0 or 1.0 USB compatible.
good luck
Nov 24, 2007 | HP Pavilion Media Center TV m7350n...
155 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
