am trying to connect LG dvd recorder RH265/266 to a 50" fujitsu plasma P50XHA58E. TV has no scart and dvd no HDMI. Have tried component video connection without any luck.Is it possible to do some other way? Is there such a thing as a scart to HDMI lead?
the plasma starts to have distortions (vertical lines following color patterns in image) once it has...
(More)
the plasma starts to have distortions (vertical lines following color patterns in image) once it has been on for a couple of hours ......there is no dust or dirt build up (took off the cover, completely clean inside). The vertical lines are either in the upper or lower half of the screen. Best example is an empty input: the lines follow the color and pattern of the text (e.g "RGB1", or "Video 2").
I just hooked up Verizon Fios service and concurrent with this hookup (couple days later)I'm getting...
(More)
I just hooked up Verizon Fios service and concurrent with this hookup (couple days later)I'm getting two vertical grey borders, one on each side of the screen. They are about 5 inches wide and lite grey and the picture can be seen through the grey verticle "bars". I would appreciate any ideas. Thanks
When I turn on the Plasma, Its dosn't start up. I have to change the mode, from video 1-4 and back...
(More)
When I turn on the Plasma, Its dosn't start up. I have to change the mode, from video 1-4 and back to RGB1 It may take serveral trys to get this done. I know it going to start when the screen show it finally has gone to any of the modes, then I chose RGB1 and it works. In addition another problem started at the same time, after maybe an hour of viewing I get a grid pattern on the sreeen. I can make the grid pattern go away by changing to any othe mode and back to RGB1.
I have a 42"acoustic solutions lcd42761hdf tv and have just got a virgin media vbox.I cannot...
(More)
I have a 42"acoustic solutions lcd42761hdf tv and have just got a virgin media vbox.I cannot find the tv codes so the remote from my vergin vbox works the sound .Ive tried searching help and support on my vbox but my tv isn"t listed
