Question about Amana Refrigerators
Amana side by side refrigerator #12858125 mold and mildew on rubber seals
    Sergeant:
    Champion:
  • 291 Answers
Open the doors, lay towel on floor underneath and spray the seals with 409 and it will eat it off and then dry off and use a little vasiline to put on seals and that will keep the soft and last a lot longer / please remember the rating / thanks / larry
Posted on Nov 27, 2008
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Extreme mold on the gasket. How do I remove the mold and odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer Odors of Mildew
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Amana refrigerator door gaskets not inflated and do not seal prop
you might need new door seal :
Refrigerator gasket Number: 67003548 70$ and see if it EZ to replace...good luck
Jan 01, 2010 | Amana ABB1927DE Bottom Freezer...
Terrible odor from rubber seal around door. Don't know how to remove seal
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Oct 14, 2009 | GE WSXH208A Front Load Washer
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Allways smells like mildew when open up
Yup, my front loader has the same issue. I found the rubber seal around the door has a fold in it that holds water and sometime candy wrappers and various stuff from pockets.
By wiping the fold in the seal out on occassion and not closing the door in between uses, the issue was resolved.
Jul 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell from rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Open Questions:
Mullion heater connection for Amana 84" Integrated bottom mount refer model B136CAR3 mfg P1318402W. I need to hook up the mullion heater that is under the freezer, component P/N 12401301. But I cannot find the mullion heater connection point. According to the specs it's installed in the foam and not wired from the factory and is for service purposes. The reason for this is that the water from the defrost cycle re-freezes and clogs the drain hole. Eventually the ice gets almost an inch thick and it's SOLID. The freezer drawer cannot open, so I have to thaw it all out and pry it open. I've done this dozens of times over the years! The service tech never figured it out. But with help of my boat-refer-expert brother we found the solution at the high level. Devil is in the details. According to the instructions: make a slit and peel back the white vinyl harness sleeve that goes to the water valve, pull out two wires (black and white) that aren't connected to anything (yet). Then "locate the mullion heater leads at the left side of the cabinet and connect to the back and white leads". Then Wrap vinyl sleeve with electrical tape to seal the slit. OOOOOKAY.... I found the unconnected leads in the harness that goes to the ice maker water valve. They have male bullet style plugs and clips (a little corroded) but I cannot find anywhere to connect them... Is left side of the cabinet as viewed from the front or back? The main harness is on the left rear area. And if I make the slit long enough (which is very difficult, then the wires could make it back there. If I only could find where the mullion heater's connectors come out. Of course the wiring diagram only shows the mullion wiring as optional and not connected to anything. I really do not want to lay this 500lb (at least) beast on it's side. It already fell on me and my daughter, but a countertop and pallets save us. This refer has been nothing but a pain to deal with ever since I bought in 2001. I don't want to get rid of it, since it has custom wood panels that go with our kitchen, and I fell on hard times (due to illness) and cannot afford a new one. It fixed many things on it already. Such as the problem where the relays weren't soldered properly onto the main logic board, which fixed the non-defrosting problem and the freezer fan not working. But now the drain hole plugs with ice. So I read that many freezers have a 5W to 20W heater that runs all the time to keep the hole from freezing. Especially if water gets in the insulation under the floor of the freezer. Anyway, can anyone tell me how to find the connections to the mullion heater? Is it in the outside-rear channel up back of the refer? it's pop-riveted on. Thanks! Scott
May 12, 2017 | Amana Refrigerators
Refrigerators Logo
99 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
