Question about Sony KP-61S65 61" Rear Projection Television
Dull picture on my KP61s65
I bought the unit in 1998. I have been told by some not to try to clean the mirror or light guns.
One guy told me that there was no mirror to clean.
What do you recomend?
  • dmjach Dec 07, 2008
    The information provided by electronick is very good.
    I have been cautioned by a number of "experts" NOT to try this procedure on my own, but now I am going to give it a shot based on electronick's recommendation!
    Thanks much!
  • 505 Answers
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Posted on Dec 06, 2008
Do I need to clean the screen on a DLP television? I have only changed the bulb. I feel like the picture is getting less sharp.
Not the screen so much as the projection mirror which is located on the rear wall of the Set. If the mirror gets dull it can make the picture dim and dull looking. Cleaning the mirror will help. Some models have a small mirror which projects the image back onto the rear mirror. Dont use windex, just a damp cloth then dry good.
Jul 21, 2011 | LG Televison & Video
My tv is 8 years old and the picture is not as bright or clear as it used to be. Can the mirror be dusty?
No,the three CRTS tubes guns coolant chemicals are not as good as before,will causes this problems. Like old dull and hallow colors pictures?Tries websites like, to buy a kit to replacemt of it coolant chemicals of one or all three CRTS tube guns.The coolant chemical kit should came with a DVD tutoring how to do it too.
Jan 03, 2011 | Hitachi 57SWX20B 57" Rear Projection...
Dull picture how do I clean blub?
Its the small mirror in front behind the screen assembly needs cleaning. Dust gets the picture dim and dull looking.
Sep 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The picture is dull, what i have to do for the TV?
The usual cause of the DLP's geeting dull is the front small projection mirror gets dusty and needs cleaning. The mirror is located dead center in the front after removing the screen assembly. Its a small mirror directly in front of the lens assembly of the light engine.
May 10, 2010 | Mitsubishi WD-62531 Projection Television
How do I get my TV open to clean color lights I have a Hitachi 42in projection tv
You can take the back cardboard cover off to get to the lenses on the picture tubes. Usually, if the picture is dull because it needs cleaning, the mirror should be cleaned. You can remove the top half of the back of the tv and the mirror will be mounted to the inside of it.
Jul 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sony kp61s65 dull picture
well I had the same problem and my husband opened it up and cleaned it and now the picture looks very good. So u might try openning it up and cleanning it ur self.
Nov 27, 2008 | Sony KP-61S65 61" Rear Projection...
1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
May 04, 2008 | Mitsubishi VS-60601 60" Rear Projection...
How can I clean the mirrors on this tv?
to clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Feb 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Dull screen
Dec 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-61S65 61" Rear Projection Television Logo
227 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
