Question about Canon PowerShot SX100 IS Digital Camera
The camera won't turn on.
The shutter opens but the camera remains off. On the screen it says that there is a shutter malfuction please restart the camera, but the camera itself won't turn off
  • 4 Answers
Did you try taking out the batteries?
Posted on Jan 16, 2009
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
When i turn my camera on the screen is black. when i take a picture the screen remains black and when i press review of the picture i took that is black as well. is that a back light problem or something...
Try downloading the picture to your computer to see if it is also black. If so, then yes it may be a shutter issue. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 21, 2010 | Kodak EasyShare C330 Digital Camera
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
Canon elph 880 can display pic's but can't take a pic,,,,screen remains black and new pics are black
Aug 01, 2010 | Canon PowerShot SD880 IS / Digital IXUS...
When i switch on lens comes out and opens but
One of three things. First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't correct the problem, read on.
Second potential issue, if your camera's a Canon, and if your camera is in the following list, it's likely a CCD problem. Please see this link.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
But if your camera was not listed above, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
May 03, 2010 | Canon Cameras
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 12, 2009 | Canon Cameras
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Panasonic DMC-LZ2 Camera
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens. Then open the camera and see if the ccd flex is correctly plugged in.
Jan 13, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
