Question about Navman NavPix N40i GPS Receiver
Lack of power
I have a power lead wired into my ignition so I do not need to use the external battery facility. My N40i periodically cuts out if I am stopped at traffic lights. What setting should the power be on within the system where it gives 'never' to XX minutes for both battery and external. Please, please advise.
  • phil430 Nov 29, 2008
    Many thanks indeed to guest 007. The solution haqs done the trick.
  • 3 Answers
Is it the power cut-off or the fact that you are not moving?
The Auto-off feature will turn off the unit when no movement is detected. Meaning, when you come to a stop and do not move for a minute, two minutes, or what every amount of time you’ve set, the until will turn itself of saving you power. You can also set this for the DC power cord. Mine is set for 5 minutes.
Posted on Nov 28, 2008
Is the stereo supposed to stay on once the ignition key is turned off on a Peugeot 307 year 2004?
I don't have specifics on that vehicle because it is not sold here in the US but most newer vehicles have a "Delayed exit" feature that keeps those components active until the door is opened.
Dec 31, 2014 | 2004 Peugeot 307 SW
I cut the wires leading to the antenna and i lost my power locks power windows alarm and radio pre sets wha do i need 2 do
check your fuses, you must have blown one or more!!never cut wires while your battery is connected and never reconnect your battery while wires are cut and exposed!!
Sep 27, 2010 | 1995 Nissan Maxima
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Scooter HID headlamp leading to power loss
Cutting the wire will do. My Mio also have a HID any that's what we did (cutting one wire). But you can also try alternative like installing a fast charger. So you can charge up your battery fast as you use your HID.
No problems encountered with my HID using the cutting methode.
Sep 30, 2009 | 2006 Yamaha DT 125 RE
Kawasaki zx 6r, no ignition spark from plugs. Coils get 12 v. it seems that cdi is working as griund seems to be cut when trying to star. I have checked the plugs against motor and frame.
check your spark plugs leads
the CDI unit need to be tested for power and make sure that no wires are touching the frame as this could stop your ignition .
the cut off switch could be faulty too .
check all power sources around your motor as a wire could easely burned and earth itself .
Sep 20, 2009 | 1995 kawasaki ZX-6R Ninja
Cutting out while driving and lack of power
clean injectors change plugs and wires
Jul 30, 2009 | 1986 Ford Bronco
Wiring an alpine cdm9807 rb to a citreon berlingo van
The 'illumination' wire is to hook up to your headlight switch to back-light all buttons when headlights are on. The pink and black audio interrupt I believe is for hands free cellphone communications it will cut out audio when you have a call and have your hands free hooked up through your stereo. The remote turn on is for external amplifiers it provides a small amount of power to to turn on/off external amplifiers. As far as your unit not working I would make sure you have a sufficient ground using a voltmeter and make sure your battery lead is fused and fuse is not blown. You should have a memory lead(maybe yellow) that need constant 12v and a ACC power that needs switched power that is only on with key(usually red). Hope this helps! :)
Feb 25, 2008 | Car Audio & Video
Navman NavPix  N40i GPS Receiver Logo
59 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
