Question about HP Computers & Internet
Hard disk not exist - HP Computers & Internet
  • c r
    c r May 11, 2010
    more info. what os? type pc, hdd, other hardware?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Check connections specially the IDE cable, if it's the only HDD for the pc, make sure it's connected on the end part of the cable. You may also need to verify the jumper setting on the HDD. A diagram with the label on the HDD will show how to set it. Usually if it's the only HDD on the pc, it's supposed to be set to master. Good luck.
Posted on Nov 27, 2008
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Hello my laptop wont open,it brings numbers that ask me to insert a boot disc,i dont have any ,what shall i do to start to start my windows.
Hi "Wambuilyds"
It show no hard disk is detected in your laptop, please check your BIOS to know the Hard disk is detected, also try to re connect your hard disk.. if the problem exists buy new Hard disk and install windows again,, Thank you
Aug 27, 2011 | Toshiba Satellite Pro L300 Notebook
I am using a compaq presario SR 1435IL. I want to know whether i can use two internal hard disks and also upto what capacity is it supported I already have a 320 GB western digital hard disk. Does it...
hi, i believed there is no possible way of putting 2 internal HDD in 1 laptop, seems the area of the existing HDD inside is already limited and also crowded of some other parts...and its not designed for 2 HDD either. the best way for me to advice is upgrade the existing HDD to higher capacity from the existing " GB " to " T " or add up a big capacity 2.5 " pocket size external HDD.
Aug 26, 2011 | HP Compaq Motherboard
I attached a sata hard disk in addition to the existing ide hard disk drive in my pt800ce-a motherboard. But the system cannot detect the said sata hard disk. what should i do?
If your existing system is IDE motherboard your new SATA drive will not work as it will have compatibility issue, also the MB will not support it.
The same goes for RAMs, 2 uncompatible RAMs will make the PC slow down or keep shutting down....
I guess you have used an adaptor to connect a SATA disk/cable to the IDE MB, check that, it may be the issue also.
Regards
pls leave a feedback and reply
Nov 11, 2010 | EliteGroup PT800CE-A Motherboard
Vista wil not boot .. screen says no bootable device
Get into Bios and
1. check if the computer can "see" your hard disk,2. check if the bootable device is the hard disk.
If these options are ok and problem still exists maybe our hard disk is damaged or bad connected.
Oct 02, 2010 | Acer Aspire 7720 Notebook
I want to trasfer the data from old hard disk to pen drivesI have installed a new hard disk in the existing system. Afraid the old hard disk may have virus
you must have anti virus protection for your PC and updated before you plug the old drive..
if you plug the old drive do not open any folder..scan with your anti virus defore you transfer any data...
May 24, 2010 | Seagate (9W2041-337) 40 GB Hard Drive
Hard disk not exist
make sure that if it is the only drive you have, to have the jumper set to master in the back of the drive.
Mar 08, 2010 | Computers & Internet
Acer T-180 hangs at "Verifying DMI Data"
The cause of this problems is a corrupt boot files, Settings for hard disk drive are not correct,Floppy diskette or CD in computer causing issue, Boot devices not set properly, BIOS corrupt or misc. hard disk jumper setting not set properly, Connections loose or disconnected, Bad Hard disk drive or other bad hardware.
Note: Try this first. Check the cable setting of your hard disk in the BIOS. try swithching it to IDE, SATA, RAID. save your seetings and restart your computer.
if problem still exist... Follow this steps..
Step 1: If you have a USB stick with capacity of 4Gb and up or another hard disk... try installing a fresh Operating System in the USB stick or in the extra hard disk that you have.. after you install.. boot to bios and set the Primary boot in the extra hard disk or Removable Device (USB) save your settings and restart.. your computer will start normally booting the windows in your newly installed extra hard disk or USB stick. when you are in the Desktop, now try accessing your old hard disk and copy your files.. after you backup your files to the new installed hard disk. go to step 2.
Step 2: Turn off your computer... uninstalled the newly installed hard disk or USB.. after you uninstalled the hardware.. turn on your computer and reinstall your Operating System again. if the problem still exist go to step 3.
Step 3: if the problem stil exist. i think ther is something wrong with your hard disk.. try installing the OS again in second partitioned of your hard disk.. create first partition, then second partition. then installed your OS in second partition... if the problem still exist and you cannot go to windows desktop.. maybe your hard disk drive is damaged...
Hope I Can Help
CLCTECH
Apr 23, 2009 | Acer Aspire™ T180 PC Desktop
Hard drive is full
Aquire disk imaging program such as norton ghost. Install 2nd, larger HDD into existing computer. Boot computer using ghost boot disk. "Image" existing HDD to newer, larger HDD.
Remove existing HDD. Set 'new' HDD to proper position (Master, etc).
Boot computer.
Joy.
Feb 19, 2009 | Microsoft Windows XP Professional
Computers & Internet Logo
2,162 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
