Question about Motorola Mobility H700 Wireless Headset
I dropped and it came apart
Dropped it and the buttons on the sides popped out .,.. how do it fix it?
  • mooseo Jul 31, 2008
    Thanks for the answer.
    "If you need more space you can take it apart farther however be careful
    not to remove a little plastic piece that is used to turn the unit on
    when the boom is open."
    Hypothetically, say, what if that little plastic piece were to have popped out as well... any suggestions on getting that back together?
Solved it.
If you need to take it all the way apart, here's the scoop:
Get the top cover off by popping it up at the hinge side (this is what pops when you drop it)... then at the charging end, slide the top towards the hinge to slip the clips out from under something.
the folding mic tells the board it is open by a small z-shaped piece of plastic. The skinny end of this fits into a tiny hole in the bottom of the case and the fat side slides up and down in a little round space over on the side of the case. There is a rubber button with a dark piece that sits on top of the round space. The dark side of the rubber piece presses against a round circle on the circuit board and tells it whether the mic is open or closed. Once you put it all together, you have to press the board down pretty firmly to tell if it is all working.
Then put the volume buttons back in place and slide the top back on.
Posted on Jul 31, 2008
Its really really an easy fix. the unit snapps apart, starting from the end on the oposite side of where the unit is charged. Don't take it farther apart than you need to slip the button back in place on each side and snap it together. If you need more space you can take it apart farther however be careful not to remove a little plastic piece that is used to turn the unit on when the boom is open.
Posted on Mar 22, 2007
What can i do if the back and forward side buttons not responding?
Take it apart & see if their is anything
broken inside
Then a new one
Aug 15, 2014 | iHome IH-M810C Mouse, Carbon
Dropped my ps3 giotech sc-1 remote, L1 does not respond now
Most common for aftermarket controllers, they are built cheaply and drops like that have a tendency to break something inside. My solution, buy a new one, it's not worth the time or effort to take apart, diagnose, and hope you can fix it.
Mar 20, 2014 | PlayStation Gioteck Ps3 Sc1 Wireless...
Got the basketball poles stuck together and theyre not aligned
Dropping the stuck poles definitely WORKS! We had stuck basketball poles from a Spaulding 54 inch together wrongly. Dropped them on grass from shoulder height 4 times and they loosened enough to pull apart.
May 01, 2011 | Lifetime 3819 Impact 44" Basketball...
I have a Bose remote that I dropped several times and I want to know if that could be fixed. It is RC28T1
Yes it can be fixed if you have patience and know your way around soldering.
FIrst its tough to take apart. I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose
The problem is that the broadcasting antenna at the top of the remote is very a very thin wire wrapped around a heavy cylindrical magnet and its solder points are extremely weak. You most likely dropped it and it came loose. I re-soldered mine and it worked perfectly.... until it broke again. The leads are very small and hard to fix.
Chalk it up to poor design.
Oct 26, 2010 | Bose Lifestyle 28 System
I have a RC28T1-27 Remote that suddenly no longer works. Put in new batteries and it seems like there is no connection. Will not work unless you keep pressing buttons repeatively.
It is hard to take apart.... I got mine apart by wedging a screwdriver in and twisting until it popped apart. (nothing broke) I started at a bottom corner and worked my way up the side until it came loose. It is a fairly easy fix if you know how to solder.
Jun 29, 2010 | Televison & Video
Dropped wireless mouse and wheel shifted & buttons hard to push
I had a similar problem and was able to fix it. The left mousebutton was clickable, but needed extra force.
After opening the mouse I found that at the side of the mousewheel there was notch pointing upwards, preventing free movement of the left mousebutton. I was able to rotate the ring with the notch back into horizontal position after gently pushing the housing surrounding the mouse wheel wider.
Apr 25, 2010 | Logitech Cordless Mouse
Know how to put the ice bin latch and spring back together
I had the same problem. When you put the spring back on the little arm towards the button, use a mini screwdriver or something to pull the spring back and pop the latch part back in the indented spots. Then, it will seem stuck but you just put some pressure on the curved side of the latch - opposite from the button and it will "pop" back into place.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Drivers side door
Pop out the window buttons part of the armrest and disconnect the wires. Do the same with the trunk and fuel door buttons. Pop out the two little plastic/rubber whatever they are pieces out of the door pull strap and remove those screws. There's another screw on the bottom edge of the door and the outer edge by the reflector. Pop the bezel out from around the door handle and there's another screw. Pull out and up on the door panel. If you don't know your door code now would be a good time to write down that 5-digit number on the lock control box. You might not have to pop out the button panel or trunk/fuel buttons if you can get your hands behind the panel and take the harnesses apart but you a bad dude if u can.
Oct 22, 2008 | 2001 Mercury Grand Marquis
The screen and keypad split apart!!!! please help!!!!
You need to provide more information for us to determine what was cut, is it still working? If it's not the keypad pad then you should be able to use it, if not it may need to be repaired.
Hope that helps
Dec 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility H700 Wireless Headset Logo
504 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
