Question about JVC KD-G230 CD Player
Ihave a JVC G230 and there is no sound
When i installed it i hade sound to all 4 speakers and it went dead and there has been no sound since i checked al my wires everthing is wired correct so i am not sure what to do, I have power to the radio but no sound to the speakers
  • jbgird Jan 18, 2009
    I have this same problem with KD-G340 model JVC in my Dodge ram 1500. What is the deal?
    New Friend:
  • 74 Answers
You have one speaker that has a short, a good way to find it quick is turn radio off and on if any of them pop even the slightest that is where your problem is...if you dont hear a pop check that all wires are not touching a ground somewhere this send the unit into protection, just one speaker or wire will do this .it keeps the radio from burning up...
Posted on Nov 28, 2008
00 vw passat 2.8 motor did timing and thermostat now have ramdon misfire on 1 3 4 6 everthing on the dime
vw passat 2.8 motor John, check the spark plug wires for proper location, Timing belt may have been installed in not quite right position. Verify new belt installed correctly. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
VW Passat Timing Belt Installation Instructions for 2 8L 30 Valve
Thread Locate Top Dead Center TDC
http://www.wikihow.com/Find-Your-Engine's-Top-Dead-Center-(TDC)
Mar 26, 2016 | Cars & Trucks
I recently installed 4 speakers, a deck, an amp, and subs into my truck. About 8 hours after I installed them the speakers suddenly went down, the subs kept thumping, but the speakers are down.
The speaker wire connected to the amplifier if you used one could have come lose or in the back of the cd deck could have come lose. Just check those basics first to make sure everything is strongly connected and make sure you have the correct gauge wire because if you have something rated to high or too low it might not create a solid link
Sep 20, 2011 | Car Audio & Video
My e470 main speaker on the front speake does not work. Ive checked the wiring and memenbrane al all is in order. Does it mean the speake \r is blown. Can I have it repaired or buy a new speaker if so...
It's not clear what BRAND of speaker we're talking about here. If it's JAMO...
It IS bi-amp capable. Is the jumper in place?
You could disconnect the jumper and measure its resistance of the main speaker with an ohmmeter, dead short or open is a dead speaker. Something around its specified impedance would be normal. Take a small battery and just briefly touch the speaker leads. It should make a static-like sound. If it DOES, go back to the wiring checkout.
Apr 23, 2011 | Audio Players & Recorders
Clock set up jvc kd-g230
Go to the link below and on the bottom right of page 1 will tell you how to set the clock.
http://resources.jvc.com/Resources/00/00/91/GET0408-001A.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 28, 2010 | Car Audio & Video
How do I connect my Ipod to a JVC KD-G230?
The cord you are using is an audio cable with a 3.5mm plug with two black bands on the plug. The JVC Source button has to be pressed until AUX shows in the display. The volume on the iPod AND the volume on the deck affect the sound - turn the iPod up to 70% volume for best results.
Mar 28, 2010 | JVC KD-G230 CD Player
What color goes to which speaker?
Check the following link:
The directions on page 4 indicate:
White = Front Left Speaker
Gray = Front Right Speaker
Green = Rear Left Speaker
Purple = Rear Right Speaker
The plain colored wire is the + side of the speaker.
The colored wire with a black stripe is the - side.
Hope this helps!
Feb 05, 2010 | JVC KD-G230 CD Player
JVC KD-G230 will not work after my battery died
the battery probley shorted out your deck i think its time for a new one
Jan 11, 2010 | JVC KD-G230 CD Player
How to install a jvc stereo kd-g230 in a chevy trailblazer 2002
First you need to get a wire harness for the Chevy (check Ebay) then follow the wiring instruction inside the package on how to join the spliced wires togother. After joining the wires togother plug the harness in and stuck the JVC into the recess where the old stereo was and thats it, it should play if not you don`t have a good ground, ground the body to the frame.
Dec 19, 2009 | JVC KD-G230 CD Player
How do you use bluetooth on the jvc kd-g230
That model does not have bluetooth installed on it unless you buy an aftermarket bluetooth adapter.
Nov 14, 2009 | JVC KD-G230 CD Player
JVC KD-G230 CD Player Logo
126 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
