Question about Saws
The delta universal miter saw stand will not adjust to level posi
New delta universal miter saw stand will not adjust to level position.
What is wrong?
  • 37 Answers
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 28, 2008
Manual for 36 136 stand
Here is a link that should have it. Good luck
http://www.manualsonline.com/support/delta
May 02, 2014 | Delta 36-136 Universal Miter Table Saw...
How do you "unlock" the Delta miter saw?
To unlock a miter saw, push down on the saw to unlock the head and loosen the knob on the table to make adjustments. Start using a miter saw with help from a custom furniture maker in this free video on woodworking tools. Read more: How to Unlock a Miter Saw How to Unlock Miter Saw Best Miter Saw Reviews Real Man Miter Saw
Oct 22, 2011 | Delta SM100M 13 Amp 10" Compound Miter Saw
HOW DO YOU UNLOCK THE ARM ON A DELTA MITER SAW 36-075, IT IS NOT A STAND BUT THE ARM ITSELF?
Here is a link to an exploded parts diagram and instruction manual for that saw.
Normally, all that is required is that you unscrew the handle and turn the table, then lock the handle in the desired position. But as with many older saws, the table may become jammed with dust and foreign objects and need to be cleaned and lubricated in order to work properly.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2011 | Delta 36-136 Universal Miter Table Saw...
Manual for Delta 10" compound miter saw 36-220
The Instruction Manual for the Delta 10" 36-220 Miter Saw can be downloaded from the following site:
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=36-220&selectedType=10255
Note that there are three models of this saw. The model numb r on your saw will be followed by -1, -2 or -3.
Select the model number you have from the on-screen drop down box. When the page refreshes download your manual by clicking the icon under PRINT DOC.
Sorry someone has not responded sooner.
Sep 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Cuts not square-bevel adjustment
Here's something to try. Get a dial indicator or a drop indicator to measure the blade wobble. Clamp the indicator to your miter gage or use a magnetic base or whatever. Position the indicator so that it contacts the side of the blade as near the outside diameter as possible, then rotate the blade by hand. If there is any warp to the blade, or bend in the arbor, or something out of square where the blade mounts on the arbor, this will pick it up. If that is all good, maybe you have a couple of teeth that were miss-sharpened and are sticking out to the side more than they should (causing a virtual wobble at the tooth end). You could position the indicator on the side of a tooth, then slowly rotate the blade backwards looking for the max reading on each tooth. You should repeat this on the other side of the blade too. Total wobble should only be a few thousandths. Good luck!
Jan 24, 2010 | Delta 36 - 981 Electric Table Saws
Need to adjust Miter gauge for Delta tablesaw 36-977. The 90 degree stop is off
1) Before setting the Miter gauge, check that the blade is straight (parallel) with the slide grooves. Lock a board in the miter gauge and place against the front of the blade, and then the back of the blade. Is the distance EXACTLY the same (it won't matter if the miter gauge isn't straight and square). If not, you'll need to loosen the table and rotate the blade holder to square it up.
2) Now Cut a board in half the flip one side over and place the cut back together. If it isn't straight, the resulting board will have a "dog-leg".
3) Adjust the miter-set-screw until the cuts on the trial board yield a board that comes out straight (or use a Framing square to check).
Dec 31, 2009 | Delta 36 977 Left Tilt Contractors Saw
HOW TO RELEASE DELTA MITER 250 SAW
All miter saws I've dealt with, there is some sort of peg located on the back arm close to the hinge. However, the arm is spring loaded so you may need to press down on the front of the miter saw to relieve pressure on the pin (peg) to allow you to pull the pin out and release the saw arm. I hope this is the answer you are looking for.
Dec 27, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
Saws Logo
350 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
