Question about Panasonic SC-HT900 System
Tray wont open
For some reason thetray wont open.i'm wondering if i should take itapart.
  • ehotka Mar 08, 2009
    I cannot get the tray to open. Took the top off of the unit and I am not sure what to do from there. A previous solution indicated to unjam the plastic mechanism. Not sure what that mechanism is. Help.
Took off the top of the player unjammed the plastic mechanism.all is good took less time thanto type this.thank you frank
Posted on Nov 28, 2008
Hi, I wonder if anybody can help me with a problem with my DV-717 DVD Player?
Hard question: Have you considered opening it to see what mechanism is doing and also to make sure something that does not belong inside got there in the mechanism?
I have seen where somehow a second disc got inserted and if the mechanism jams for any reason odd issues and or shutdown may happen.
Apr 09, 2012 | Pioneer Televison & Video
LG DRT389H will switch on OK but the disc draw will close when a disc is loaded, but comes straight out again and will not play.
Hello
There is a loading motor and a belt associated with it, connected to a gear wheel assembly that pulls in the disc tray as well as gets it out. If the loading belt, said above, will get loose, the disc loading tray wont get into it properly. There is a sensor switch fitted inside the loading mechanism, which senses the proper tray in action, as this tray will touch it when it ahs been fullly loaded. Due to any reason, the switch said above does not engaged properly, the main system control IC will detect the loader position to be improper, and will give command to eject the tray. That is now happening to your DVD player.
If you have knledge and experience, just open your DVD player. locate the loading belt, and repalce it with a new one. You can buy this belt from most of the electronic sparepart selling shops at your town. Just keep the old belt in hand as a sample, when you go to buy a new one. OK
WISH YOU A HAPPY PROSPEROUS 2012
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 27, 2011 | Televison & Video
My crapping stupisd babeep ba beepa crazy watch your mouth playstaion 2 wont work the disc tray wont open or close and wont play cds
theres a wire right under the disk tray its small and hard to plug in but they like to come unplugged that could be the reason for the problem
Jul 03, 2010 | Sony PlayStation 2 (PS2) Console
Tray won't open.
hello,
the reason the tray wont open is because there is a problem on the mechanism that controls the opening and closing of the tray.
most likely the rubber that assists in opening and closing the disc tray.
to fix this, unscrew the player, turn it on and press the open button, it'll respond and stop.
you'll see a kind of mechanism that carries the tray, its engine is by the side of the tray.
when the tray stops responding after you've pressed the open button, try to carefully sit the engine properly and press the open button again and it will respond.
if you cannot do that on your own,try to take it to a service center for further repairs.
take care
May 30, 2010 | JVC DR-MV100B DVD Recorder/VCR
My xbox 360's disc drive not opening
Thank You Luke-7 yes it's jammed ,stuck ,seized,
Common problem ( Stuck Tray)
The reason is the eject motor is either to weak to break open
the magnetic seal created between the spindle and the hub
holding the disk firmly in the drive or there is too much friction
in the gear assembly causing the motor to stall-out
To get the tray to open press the eject wait one second
and then Firmly (HARD) slap the top of your console right
over the CD rom drive this will break the seal and release
tray allowing it to open.
The console should be open ,the Rom drive removed
and open and thoroughly cleaned out .plus I like to gap
the hold down magnetic so the eject motor can release
the tray with less force.
If you have any Questions feel free to ask
Rob
Apr 22, 2010 | Microsoft Xbox 360 Console
My little sister was playing with the burner and then it just stuck! it wont come out and wont go in! i was wondering if u can send me a picture of the inside where the cd in put in! thank u soooo much!!!
Observe under the tray. (The tray comes out for the disk)
There is a SMALL hole. Just big enough for a paper clip to fit into it.
Take a paper clip, straighten it out, leave the last U-shape for a handle to hang onto.
Gently push the paper clip into the hole. Your tray will open. This is a manual override.
Oct 04, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Wondering if anyone is any good with lite on shm 165 drives? Been trying to figure out why it wont open the disk tray. No disk inside, pressing the button makes an audible clunk noise. Pushing the pin...
Problem found on mine: tray opening mechanism is belt driven, while others are gear driven, belt tends to stretch with time and slips on motor pulley, gears do not. Just cheap built. Remedy= Belt can be removed from front with open tray, soaked in rubber rejuvenation liquid for few seconds, cleaned and dried, re- installed on pulley.
It works now, but for how long, I have no idea.
Aug 15, 2009 | Lite On SHM-165P6S DVD RW Dual Layer...
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Tv wont turn on
Mine was doing that then it quit even turning on too so I replaced the 4 Capacitors today on the power supply board that had bulged up on the top 3 had split open they where on the top right corner of the board where the ribbon jumps from the power board to the main board with ones from Jameco Part Number 606521 they worked perfect but make sure you put them in with the correct polarity easy to do just keep an eye on it. Very simple repair and took me about 30 min to take itapart solder on the new ones and put it back together all for under $10.
Jun 21, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
K800i how to fit a new screen?
ensure u take battery n u will find some screw which open panel from back ok then u seperate the case and u can place the new one
Feb 18, 2008 | Sony Ericsson K800i Cellular Phone
Panasonic SC-HT900 System Logo
125 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
