Question about Gaggia Evolution Espresso Machine
Water through frothing wand
When I press the middle button to brew espresso, hot water shoots out of the frothing wand instead of the espresso brewer. I don't see any sort of obstruction in either one, but I can't get the machine to do anything else.
I'm a college student, so it hasn't been used in a few weeks.
I don't understand how it worked fine before and doesn't now. Please help!
It might sound silly but you haven't got the steam valve on the right hand side open have you?
Posted on Dec 20, 2008
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
B40 WR Keurig shooting out water instead of brewing
Turn off your brewer and use an unfolded paperclip to clean out the holes in the top needle
Dec 26, 2012 | Keurig Special Edition B60 Coffee Maker
Water shoots out of steam valve and can't make espresso
Samantha,
The steam function and the expresso use the same elements to create the steam but the valves will direct the steam to the expresso unit or the steam arm. Most likely you have a faulty valve. In most cases the valve will not open until the pressure gets to the right level. If you are just getting hot water out of the steam arm instead of steam via the expresso unit it most likely means that the valve is faulty. The valves can be replaced but is not easy. You will need to have the unit serviced or you could try to replace the valves. Make sure the flow meter is working before you replace the valves. You can check the operation of the flow meter by running the hot water cycle and making sure that you get the right amount of hot water. Good luck!
Nov 21, 2011 | Krups XP2070 10 cup Coffee Maker/15 bar...
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Water leaks during brew cycle
you have a split in or a loose conection where the water pipe conects to the boiler so water comes from there and the lack of pressure is making the machine work harder which makes it sound bad
Dec 14, 2008 | Saeco Vienna De Luxe Espresso Machine
Francis!Francis!3X overheating
Your thermostat has failed. The middle button is the pump. The bottom button is for the steam mode. If you are getting steam instead of hot water when using the pump, then the boiler is way too hot. Either adjust the thermostat or try descaling the boiler.
Feb 13, 2008 | FrancisFrancis! X3 Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Gaggia Evolution Espresso Machine Logo
132 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
