Hi my name is Bryant I bought an eletric watre heater ,my trouble is ,the old waterheater had a red wire green ,black ,yellow and ground. the new heater has only black red and ground, my house has a sepreat meater for the heater. dont know what wires to connect or cap,please help.
  • 306 Answers
Can you trace it back to breaker box? I'm thinking green and yellow are not needed but only way to tell for sure is breaker box. Volt Ohm meter would be helpful also.
Posted on Nov 27, 2008
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
Replace et724-A with new digital timer 15313
You are install GE 15313 timer
Open following link to identify timer
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
15313 timer does not require Neutral wire.
The timer you are replacing has neutral wire (White wire)
So replace timer wires 1:1 except do not connect timer to white neutrals.
Keep in mind the 15313 is for incandescent lights only and is not for CFL or LED lights.
If you want timer for CFL, then install one of the other timers shown on page.
Apr 29, 2012 | Intermatic Inc. EJ500C Digital Wall Switch...
Having trouble wiring in my new stereo Ford Contour SE. I cut out my old stereo and was gonna wire it to my new one but the wires dont match so i bought a adapter kit... only thing is the wires i...
Car Radio Battery Constant 12v+ Wire: Orange/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: White/Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Brown/Yellow
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Brown/Yellow
Car Audio Rear Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Door
Left Rear Speaker Positive Wire (+): White/Purple
Left Rear Speaker Negative Wire (-): Brown/White
Right Rear Speaker Positive Wire (+): White/Purple
Right Rear Speaker Negative Wire (-): Brown/White
Jun 06, 2011 | Car Audio & Video
I just bought Alpine car stereo CDE-100EUB but I'm having trouble connecting it to my old car toyota Rav 4 2004 model because the wire harness are different. also the alpine wires are more in numbers than...
Please let me know if you have any questions, and thanks for using FixYa.
2004 Toyota RAV4 Car Stereo Radio Wiring Diagram Alpine wire color
Radio Constant 12V+ Wire: Blue/Yellow yellow
Radio Ignition Switched 12V+ Wire: Gray red
Radio Ground Wire: Brown black
Radio Illumination Dimmer Wire: Green none
Radio Antenna Trigger Wire: N/A blue
Radio Amplifier Trigger Wire: N/A blue/white
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Pink white
Left Front Speaker Wire (-): Purple white/black
Right Front Speaker Wire (+): Light Green gray
Right Front Speaker Wire (-): Blue gray/black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Black green
Left Rear Speaker Wire (-): Yellow green/black
Right Rear Speaker Wire (+): Red violet
Right Rear Speaker Wire (-): White violet/black
Jan 02, 2011 | Alpine Car Audio & Video
Replaced fan motor for outdoor ac unit old fan has blue,black,red,and green wires new fan has brown,black,yellow,brown/white and green what goes where
Hi, the 2 - brown wires are for there own run capacitor they should have sold you. One of the browns will have a white stripe. The new cap has only 2- terminals and you put a brown on each side. The black and yellow wires are both hot which 1- will go to 120 volts on the load or out side of the contactor, and the same with yellow, 120 volts. This gives you 220 volts to run the motor. Look on the new motor and you will have a diagram or on a paper that comes in the box. The old motor used the dual cap to run the compressor to. The green is just a ground wire. Screw it to any metal part or screw. You should be able to put the black and yellow hot wires where the old black, red, or blue were as long as they are 120 volts which I am sure they are. Get a cheap tester when you go get the cap for the new motor, and check the old blk, red, and blue terminals to ground and you should have 120 volts on at least 2 of them. Put the new yellow to 1 and black to another, browns to the new cap and your off and running. Keep me posted. I do this everyday. Please be kind when rating me, thank you.
Shastalaker7
A/C, Heating Contractor
Jul 09, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
Pioneer deh425 plug discription
I have one right in front of me and can tell you what color each wire is, from top left of plastic wiring port.
Black/ green ?
Grey/black ?
Blue Power Antennae
Black Ground
Black/white ?
Green/black ?
Red/green ? Left Lower row
Gray/red ?
Red Accessory/Ppwer
Orange Battery Memory power
Green ?
Dec 25, 2007 | Pioneer DEH-425 CD Changer
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
