Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 autofocus
My Nikon D50 with AF-s DX 18-55mm lens, autofocus will not autofocus, manual focus works excellent but I can't get the autofocus to work! Help! I have tried everything I know to try to fix it- resetting all the settings, going throught everything trying to change it but I just went to use it and overnight it decided it didn't want to autofocus... is it broken? Do I have to buy a whole new lens?
  • 2 more comments
  • smaywest Nov 13, 2008
    I have the same problem, found this on the web..http://ask.metafilter.com/99298/Scary-Ni...
    I tried the suggestion in the last post, to push in the tiny reset button on the bottom of the camera after taking the lens off and turning off the camera, and it seems to work at least so far. Sounds like a common problem fwith this model of Nikon, from what I have read on the intenet.
  • klem_190 Nov 29, 2008
    I used my camera just last week & I went to use it at my son's wrestling tournament today & it won't focus in auto with neither of my lenses.
  • psalas Dec 10, 2008
    I have the same problem. Wanna try this solution but don't know what's the focus ring
  • Anonymous Mar 25, 2014
    Lens keeps clicking and clicking when trying to autofocus for pictures.
I just encountered the same problem. The advice giver who forced the focus ring with autofocus engaged was right on the mark. (Thanks!) Actually, I didn't need to force it, just gave it a firm push. Voila!
Posted on May 03, 2007
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Posted on Jan 15, 2007
  • g0rpr61 May 04, 2011
    DID WHAT YOU SUGGESTED...FORCED THE FOCUS RING..WORKED
    A TREAT..THANKS..
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Apr 16, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
Jan 02, 2010 | Nikon D3000 Digital Camera
Lens works fine in manual focus on Nikon D5000 but won't autofocus.
The D5000 needs an AF-S lens to autofocus.
Nikon have not fitted the mechanical focus drive to the D5000.
Jun 22, 2009 | Nikon 10.5mm f/2.8G ED-IF AF DX Lens
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon DX AF- S Nikkor 18-55 mm lens won't Auto focus
Is the switch on the side of the lens set to manual or auto? Sometimes it's the little things like this that we don't notice.
Apr 16, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
Apr 06, 2008 | Nikon D50 Digital Camera
Nikon D50 Does Not Autofocus
replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Nov 05, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera with 18-55mm Lens Logo
1,032 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
