Question about Pioneer VSX-D711 Receiver
Vsx-d711 sound problem
The sound works well for 2 seconds then silent for one second. then good for 2 off for one, repeats continuously, no other visible errors or codes displayed.
Any help will be greatly appreciated
  • bnkrazy Dec 27, 2008
    I have a similar problem. There is an audible "pop" and the display sometimes flicks off and back on, then the sound comes back. Not every two seconds though, usually 5-10 times a day.
    I'm guessing a short in a speaker connection, because I can fix it for a while if I wiggle the speaker wires on the back. I haven't had time to go one by one and find the exact one causing the problem.
    Genius:
  • 1,175 Answers
HI...
Sounds like ( no pun intended) poor speaker wire connections.
Check the wires at both ends and make sure theyre firmly attached.
If one speaker isnt connected , the amp will reset over n over
Posted on Mar 24, 2009
I have the VSX-D711 receiver and recently added a new DVD player and re-ran the speaker wires. Since this change I have developed a new problem, after about an hour the receiver shuts down.
The problem sounds like the amplifier shutting down in protect mode. This can be due to a shorted speaker cable, or even a speaker that may be run out of phase, or too much load on one channel of the amplifier.
First check and make sure there are no cables that may be exposed and rubbing against each other. That will cause a short.
Secondly try re running and testing each speaker line as you go individually. While you are rehooking the cables up, make sure that you + and - are in the correct terminals on the speaker and the receiver's speaker outputs. Also make sure you are not running more of a load on the receiver than it can handle such as running multiple speakers on the same output. This will cause the amp to shut down. Only run a load (8ohm, 4 ohm etc..) that the receiver speaker output can handle Two 8 ohm speakers make a 4 ohm load thus making it harder for the receiver to work, and then it overheats and shuts down. Good Luck
Feb 25, 2011 | Pioneer VSX-D711 Receiver
CAN I USE STK400-110 = PAC011A
I used a STK410-030 to replace PAC011a in a Pioneer VSX-D711 without any problems.
Mar 07, 2009 | Pioneer VSX-D510 Receiver
My Pioneer VSX D711 is heating up ....VERY HOT to touch
Generally speaking heat is a byproduct of the amp working too hard. This can be caused by speakers that are not matched correctly to the amp. In other words using 4ohm speakers on an amp that is expecting an 8ohm load. If this is a new occurrance, than look for speaker wires that have frayed and are somewhat crossed. From the amp's perspective this will look like a low ohm load. The amp may continue to function correctly, but work extremely hard and generate excessive heat. This will untimately damage the amp. Check the speaker wires first.
Also, does this occur even at low volumes? If so, this again points to a short in the wires or speakers themselves.
Please update this with what you find.
Thanks,
Dan
Jan 10, 2009 | Pioneer VSX-D711 Receiver
VSX-D711
Yes.
There's an integrated circuit that steers all the input signals thru.
That has crapped out.
Jan 28, 2008 | Pioneer VSX-D711 Receiver
Poor sound
You need to connect most turntables to a PHONO input or buy a PHONO preamp. Many newer receivers do not have a PHONO input. The AUX port you are using would work fine for a device like a CD player, but turntables need to be amplified. You can buy an external Phono pre-amp from Radio Shack. I don't know anything about this site, but something like this device should work for you. http://www.phonopreamps.com/tc400pp.html
Jun 19, 2007 | Pioneer VSX-D711 Receiver
The Sound is Gone.
Hi....
The circuits that routes all the audio signals thru the amp has either died OR the power supply that runs that circuit has died.
Estimate to fix : $75-125
Apr 22, 2007 | Pioneer VSX-D711 Receiver
Pioneer VSX-D711 Receiver Logo
302 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
