Question about Motorola Mobility RAZR V3
Razr won't ring
I'm having the same problem described by HalenRush (below) except our phone wasn't dropped in the toilet. As a matter of fact it wasn't dropped at all. This is my wifes phone. She's very careful with it and she doesn't download anything into the phone. When the phone is plugged in and charging it won't ring, nor will the alarm "ring" and during charging if you are talking to someone they can't hear you and you can't hear them. If you disconnect the charger from the wall, everything operates normally. It rings just fine, the alarm goes off nice and loud and you can hear callers, they can hear you. We've had the phone for about a year. The problem just started a few days ago. Is it possible to "reset" the phone to factor setting in case the phones Software is corrupted or if a setting in the phone needs to be change? Any idea's? "Problem:posted by HalenRush on Jan 06, 2007 Report abuse Phone went into the toilet. Got it working again after getting a new SIM, but now when it is charging, it won't ring for calls or texts. Any solution? Thanks."
  • 1 more comment
  • Ken Martin Jan 14, 2007
    OK...i'm going to try this, but before I do, will a master reset effect the contents (phone numbers, pict's etc.) on the phone. I know you can save data to the sim, but I also seem to recall you can save data to the phone's memory and not the sim.
    I would guess the sim's content would be OK, right?
    It's not a real big deal if I lose anything, but thought I'd ask.
    thanks for the initial response. I'll post back after I do this with my results.
    OK, I'm going to try this. Will I lose the contents on my sim card or just the data saved to my phone NOT on the sim card?
    I'll post back after I try this to let you know how this turns out. thanks for the response
    OK, I did a master reset on the phone. still the same problem.
    To add more to the mystery. While the phone is plugged into the charge not only does it NOT ring, but it "says" it's recharging, while in fact it's not charging at all.
    We have 2 of these and swapped batteries. The batter charges just fine in the other phone. While in the other phone it seems to keep it's charge for the normal length of time so I think I eliminated a faulty battery.
    To net it out,
    1) it doesn't charge
    2) it doesn't ring while it's plugged into the charger when the charger is "hot"/plugged into the wall.
    3) if you leave the charger plugged into the phone but disconnect it from the wall it rings fine. So it appears that only when electricity is flowing into the phone that it doesn't ring or charge.
    Since I did a master reset I'm thinking this is more a mechanical problem than it is SW.
    I also noticed the pins on the phones connector looked corroded. I cleaned them off with no effect.
    Any other idea's?
    Problem Solver:
  • 17 Answers
MJM0103, If you want to do a manual reset on your phone, it is something you can do. This is how you do it. Press Menu Goto Settings and press select Goto Initial Setup and press select Goto Master Reset and press select If it asks for a code, press 0000000 It will then restart and will power back on just the way you bought it. Let me know how it works out for ya. John
Posted on Jan 12, 2007
I think that if u turn ur phone off likely it wont ring so there by michelle gaudreau
Posted on May 23, 2008
SOURCE:
The screen doesnt turn on but everything else does
i m sorry to say u but there is no other way except changing ur screen to fix ur problem.
thank u !
Apr 01, 2014 | ZTE Warp
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
My motorola razr fell in the toilet. yes, i know
You might try removing the battery pack and sim card then placing it in an area of warm air flow. If the mineralization in the water in which you dropped it wasn't too high, it might recover after several days. It's worth a try and the price is right-
Nov 12, 2009 | Motorola Mobility RAZR V3
American Standard Cadet 3 - bowl water slowly drains
try putting some food coloring in it to see if it's leaking anywhere. the coloring will help you identify where it's leaking
Aug 21, 2009 | American Standard Cadet 3 Right Height...
Describe your Eljer &
I have not heard of any toilet manufacturers offering a lifetime guarantee (except maybe for defects in manufacturing), especially since flappers tend to deteriorate with exposure to chlorinated water, fill valves eventually fail, and toilet seats do break. Pick out a replacement that suits your fancy, unbolt the old one from below, and install the new one. Don't overtighten as the porcelain could break.
Jul 17, 2009 | Eljer & Patriot& Elongated Toilet Bowl
My phone fell in the toliet
Switch off the phone as soon as possible. Allow it to dry else the circuits will be affected. Check if it works tomorrow, if it doesn't you might need professional help. Some components will require change.
Jun 03, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
RAZR v3xx
go to settings and set a ring or vibrate alert do it by going in profiles and edit them
Nov 27, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola razr
Very sorry to say you need a new phone.
liqid and electronics just don't go together
Oct 31, 2007 | Motorola Mobility RAZR V3
Dropped fone in toilet
Hi, You can purchase a spray called electric cleaner that cleans small electric components and dries very quickly. But you will have to open the phone and spray on the small circuit board inside. If it still doesn't come up after that then it might possibly be dead. Sorry and good luck Lolita
Jun 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
847 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
