Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Picture too big
Hi I recently purchased a sony wega 36 CRT TV. It has a great picture, but the sides of the picture seem cut of. So the first couple letters of the on screen guides and some of the right hand stuff is cut off. It's not a huge deal but something that should be able to be resolved. Any solutions would be appreciated. Thanks
    President:
  • 1,284 Answers
The horizontal size adjustment is in the service menu only. I would suggest someone who knows the code to do it for you.
Posted on Jan 26, 2007
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Turns on stays on five minutes works great then goes on standby
These tv is famous for high voltage it dead or cold solders to it FBT.The flyback transformer,a big black block of plastic with a red wire with a cap hook to the CRT(tv tube).U know how to solders? Take the tv aparts resolders the FBT.Or tries press the power button on/off couples times,if u get a picture.Don't touch it let it on,for three or four hours.Let the heat from the electricity to Amp up the heat,might solved this problems,without resoldering.
Apr 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture to big for the screen
You need to adjust your aspect ratio, you need to consult your manual
http://tv.manualsonline.com/manuals/mfg/sony/fd_trinitron_wega_kv32fs120_kv36fs120.html
link for user manual above.
Apr 01, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture on my sony 29" cuts out after a few minutes
I once had this problem.I unplugged it for a few minutes then plugged it in it worked , but then i took it to repair it and everything was fine
May 18, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-36FS120 No Pic/No Sound 4 blinks
You need to have the flyback on the main board replaced (a very comen problem)
This should fix ya!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Wega FD Trinitron dark Picture
probably is only adjustment inside the tv or you may need to replace the flyback
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
2001 sony wega 36" tv tube
If you turn the color all the way off the picture should have good black and white if not the crt is at fault. If it is good it could be the jungle ic or the possibly the red color driver in the crt board
Apr 06, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
KV-34HS420-Sony Tv
well based on ur info, ur tv has a prolem in power supply section, particularly regulation circuit. the regulator of the circuit seems to be mulfunctioning thats why insufficient voltage is coming out from B+ which in turn goes to high voltage circuits thats why the produced picture is insufficient. if this is very technical to u, have it check with a qualified technician.
Jan 06, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
