Question about Pentax AF-500 FTZ TTL Flash
Following a drop...
... all functions on the flash continue to work. It charges normally, but does not discharge (either throught the "Test" button or when triggered from the camera). Could this be just the bulb, or does it sound like more serious problem (damaged el. circuit)?
0 characters
1 Points
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
What should I do?
  • did you recently dropped your flash ? if no have you tried replacing batteries ? although you mention that batteries are fully charged if you are using old rechargeable batteries this might have an effect with your flas
Mar 18, 2014 | Canon Speedlite 430EX TTL Flash
Mecablitz 45 ct 4Have an old 45ct4. Which functioned when last used. Have new cell in my QB2, but flash does not turn on, as if it's not getting power. Is there anything in he flash which would have...
The flash capacitor may need formatting after a long period of disuse (years). This means a longer than normal charge time and a few charge-discharge (test flash) cycle. If however the red LED, next to the power switch, does not light up after a few seconds, the flash can be faulty. Having repaired a flash of this age is not easy, spare parts are not available.
Feb 27, 2014 | Camera Flashes
I dropped my flash, bulb broken
if it is charging OK,discharging is failed,discharging components must be replced,xenon tubr etc,contat camera tec.
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Nikon SB-800 Defect
Have you tried other batteries?
If one cell has died, there will be enough power to power up the flash, but not enough to charge it reasonably fast. It may also stop the other cells charging up properly if they are charged together. I've had this problem with poor quality rechargeables before. I think flashguns put pretty heavy demands on batteries.
Oct 23, 2007 | Nikon Speedlight SB-800 TTL Flash
Flashing auto check and test/charge
This means that your batteries are low on power.
Oct 07, 2007 | Olympus FL-50 TTL Flash
Nikon SB-29s macro speedlight
Trigger coil or a flash tube. Flash tube is easier to replace so try to replace that first. Caution before you do anything else when you open the unit locate the main 330v capacitor and discharge it before you work on the unit !
Mar 22, 2007 | Nikon Speedlight SB-600 TTL Flash
How to open case to perform tests
Remove the metal circle oposite to dial (it's glued). Under the circle you will find a metal clip connecting halfs of the flash - pull it out. Flash is ready to open.
Mar 04, 2007 | Vivitar 283 Flash
Pentax AF-500 FTZ TTL Flash Logo
29 people viewed this question
Top Pentax Camera Flashes Experts
Tom Chichester
Are you a Pentax Camera Flash Expert? Answer questions, earn points and help others
